Splines gone, few questions - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 8 (permalink) Old 09-22-2014, 07:45 PM Thread Starter
So found out the other day my splines were probably shot, today i tore it apart and yea they are gone, atleast the coupler splines, still going to get a final drive aswell just to be safe. But anywho the shaft housing is covered in rust and i'm wanting to clean it all out, went to try and pull out the shaft and i'm able to get it off the front splines but i cant get it any farther than that, is there some special way to get it out or what(or am i just making the job more difficult by trying ot remove something that doesn't need to be)? Also the moly, is this stuff good enough?
http://www.autozone.com/autozone/acc...tal&store=3742
doesn't say the % of moly but seeing as what it says that its for i would assume it will do the job pretty well.
1996 VN750
V&H pipes
HID headlight
Ear shave
Clubman Bars
Matte black plasti-dip "paint" job.
yousername is offline
post #2 of 8 (permalink) Old 09-22-2014, 09:24 PM
200% senile
Texas's Avatar
If you order the Moly60 off of ebay right now, it will be there before you can find and get your other parts shipped to you.
Shark88 had a final drive for sale and at a bargain price too. Might PM him to see if he still has it. https://www.vn750.com/forum/showthread.php?t=58769
1996 VN 750
2007 Vulcan Mean Streak SE
When I was younger I was afraid I'd die riding. Now that I'm old and falling apart, I'm afraid I won't.
Texas is offline
post #3 of 8 (permalink) Old 09-22-2014, 09:32 PM
removal (total) of the driveshaft requires it to come out the front of the swing arm.
remove the front bevel, and it will pull right out (front bevel removal also requires removing the rear exhaust pipe)
watch fleabay close. you may be able to pick up an entire driveshaft with coupler for less than a new coupler alone (thats the route I went)
michiganteddybear is offline
post #4 of 8 (permalink) Old 09-22-2014, 09:59 PM
200% senile
Texas's Avatar
When I was replacing my final drive and coupling, I had my drive-shaft all the way out because I had removed the swingarm to check out the bearings and seals.
If you try to just replace the coupler on the drive-shaft, there is a clip that holds it on that is hard to get out of there without the special tool that is listed here somewhere.
1996 VN 750
Texas is offline
post #5 of 8 (permalink) Old 09-22-2014, 10:43 PM
Personally, I would not use any Moly grease when % of Moly is not claimed on label. I desire two year assurance on Moly grease.
.....just sayin'
post #6 of 8 (permalink) Old 09-22-2014, 10:49 PM
You need a narrow pair of circlip retaining ring pliers like the ones in fergy's spline lube thread. The pair shown here are Klein 73242s.
https://www.vn750.com/forum/showthread.php?t=17274
current link to Amazon:
http://www.amazon.com/Klein-Tools-73...m/B00085EQ6G/2
post #7 of 8 (permalink) Old 09-23-2014, 06:38 AM
200% senile
Texas's Avatar
Ah yes, that's the tool, thank you. We bought that tool back when we were doing the shaft cuz' our other sets of ring pliers would not go deep enough inside the coupling to reach that clip.
1996 VN 750
Texas is offline
post #8 of 8 (permalink) Old 09-23-2014, 06:38 PM Thread Starter
Yea i'm already talking to shark about his final drive, and thanks for the info about the swing arm, not sure if im gonna go that route then. I can probably get it cleaned out good enough without taking the whole thing apart.
1996 VN750
V&H pipes
HID headlight
Ear shave
Clubman Bars
