Clunking when rolling bike - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 22 (permalink) Old 08-09-2014, 02:03 AM Thread Starter
Question Clunking when rolling bike
hey guys, i have a 95 vn750 with 23k im working on for a customer..had to replace the pulse coils (and remove the engine due to the PO CUTTING THE FRAME on the left side to attempt to remove and repair the pulse coils, i know, WTF!) Anyhow, according to the owner the bike rolled and rode fine and smooth beforehand...but the guy seems a bit..daft ..so idk. Anyhow, i get her all done and roll her off the stand, and lo and behold there is a clunking coming from the driveshaft tube 6 times per rear wheel revolution approximately.So i pull the bevel drive of and check it, TOTALLY smooth. I spin the output shaft..same thing..LIKE BUTTER. Check the U joint..again, PERFECT. Lastly i pull the rear wheel, as the sound seems to be coming from there..Spin the driveshaft by hand with the wheel off, bike in neutral..Smooth as silk..Spin the rear end..totally mint also...But put it all together, and clunk clunk clunk.Ive checked every single part, YES there was grease on the pinion splines and coupler,and they dont look bad compared to pics i have seen.I greased the splines anyway.Ive checked every microfiche and i'm not missing any parts...spent hours and hours researching the whole spline issue and disassembly/ reassembly..i am convinced i've done it all correctly.. I considered maybe i need to phase the driveshaft, but theres only one u-joint, so it would seem that it's not necessary..I'm banging my head on the wall and the owner swears it was quiet before, but he has only ridden it for 15 minutes since buying it...sooo WHAT GIVES?!?!?!? i need help here as the owner is getting antsy and i need an explanation..And when i say the splines look ok, the loaded edges of the pinion male splines have a tiny bit of peening but thats it, i havent gotten into the grease too much on the coupler but it didnt look horrendous..the spring is there, etc etc
THANKS
95vulcan750 is offline
post #2 of 22 (permalink) Old 08-09-2014, 02:16 AM
So....yer a commercial shop....and dont even make an intro thread ?....no location...dont expect many replies....folks who come here just to get info then bail, we've seen em before....actually, if you take the time to search the forum archives, the answer is already here....but sounds like ya need a quick fix to make yer buck.....
I KNOW what to tell ya....but until ya do things properly, dont expect a lot, except mebbe from the make believes.....
post #3 of 22 (permalink) Old 08-09-2014, 02:23 AM
i got your answer it is a quick fix and a fluck up on your behalf but it will cost ya
post #4 of 22 (permalink) Old 08-09-2014, 02:25 AM Thread Starter
HahA my apologies, no i'm a small shop that mainly does cars, but i'm in Brentwood NH, I'm 30 years old, have owned a number of ATV's and dirtbikes as well as streetbikes.My two babies are a 98 dr350 dualsport and a 99 Honda superhawk. My shop is called Whiskey Throttle Customs and I've done a number of full rebuilds and restorations as well as anything in between.
post #5 of 22 (permalink) Old 08-09-2014, 02:26 AM Thread Starter
haha you folk are brutal.smart but brutal
post #6 of 22 (permalink) Old 08-09-2014, 02:27 AM
check your pm's newbie
post #7 of 22 (permalink) Old 08-09-2014, 02:50 AM
stop posting duplicate threads man i can delete them all night
post #8 of 22 (permalink) Old 08-09-2014, 02:53 AM Thread Starter
the other thread has to do with an engine knocking noise..not the driveline one..this bike is really ****ed..that part is def not my fault tho..is it not in the correct section?
post #9 of 22 (permalink) Old 08-09-2014, 02:55 AM
**** didnt read it all the way thru sorry i will get it back up lol this one is in the right hole lol
post #10 of 22 (permalink) Old 08-09-2014, 02:57 AM Thread Starter
i know,hard to believe one bike could be the source of so much angst.i can see how the mistake was made though.No biggie
