won't shift - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 19 (permalink) Old 07-26-2014, 06:14 PM Thread Starter
won't shift
rolled my vulcan 750 off trailer after having carbs rebuilt, it has set for about 3 weeks now i can't get it to shift into neutral. it was setting on the kick stand if that makes any difference. any guess?
hhead51 is offline
post #2 of 19 (permalink) Old 07-26-2014, 07:40 PM
Put in first and push a little while pullung up on lever.or start it with clutch in
post #3 of 19 (permalink) Old 07-26-2014, 10:05 PM Thread Starter
It's locked so tight i can't get the wheel to roll
hhead51 is offline
post #4 of 19 (permalink) Old 07-26-2014, 10:10 PM
That doesn't have anything to do with the shifter. Put it on the center stand and find which wheel won't turn.
edit-probably the rear, make sure.
wmsonta is offline
post #5 of 19 (permalink) Old 07-26-2014, 10:28 PM
But you rolled it offa the trailer?
post #6 of 19 (permalink) Old 07-26-2014, 11:48 PM
Chasin' the blacktop
Spencer1's Avatar
Bet he bumped the shifter and popped the C clip. If so you're in for one major repair
North Georgia
Spencer1 is offline
post #7 of 19 (permalink) Old 07-27-2014, 02:54 PM
This may be way off base......
....Just thinking......
I was missing the "C" Clip, (allowed shift rod to slide/move horizontially left & right approx. 1.5 in.).....I took a piece of hose 1.5" long, split it down the length, placed it on the shift rod....preventing horizontial movement (engine) inward.....worked fine for years.
Unknown if shift rod allowed to stay inward(to the engine) if that would cause shift problems.
Is this a possible situation/solution ? ? ?
post #8 of 19 (permalink) Old 07-31-2014, 08:37 PM Thread Starter
The rear wheel is locked it will not budge
hhead51 is offline
post #9 of 19 (permalink) Old 07-31-2014, 08:44 PM
Get it on the center stand, make sure it is in neutral. If the rear wheel will not turn yet, undo the brake at the rear. Try to push the brake lever toward the rear. If it still does not turn start pulling the rear wheel.
HTH.
wmsonta is offline
post #10 of 19 (permalink) Old 07-31-2014, 09:34 PM Thread Starter
This c clip doesn't sound good. I can't get it to go int any gear, the shift leaver just moves but tyou can't feel it go into a gear. and the rear wheel won't roll
hhead51 is offline
