Transmission probs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 7 (permalink) Old 07-19-2014, 01:04 PM Thread Starter
Transmission probs
On my 96 vn750 when I try to down shift it sometimes goes straight into neutral what would cause this and how do I fix it
I am thinking it my have to do with bad forks not sure
Devildrivemel is offline
post #2 of 7 (permalink) Old 07-19-2014, 01:37 PM
You need to be more specific....
Does it go into neutral only from 2nd to first , or from other gears too?
Does the neutral light go on?
Are you moving when this happens?
The bike has a positive neutral finder, that makes 1st to 2nd and back a little tricky to do without hitting neutral.
post #3 of 7 (permalink) Old 07-20-2014, 12:47 AM
Make sure youre runnin a 10-40 NON synthetic too...synthetics make the bike wonky, and no need to run heavier oil unless yer like in Arizona.....10-40 works fine for most....mebbe a 10-30 for Canada and Alaska....
post #4 of 7 (permalink) Old 07-20-2014, 12:56 AM
Chasin' the blacktop
Spencer1's Avatar
While I'm no oil expert wouldn't 10-40 and 10-30 have the same viscosity in cooler situations?
North Georgia
Spencer1 is offline
post #5 of 7 (permalink) Old 07-20-2014, 12:04 PM
There are a lot of folks running synthetic oil here. 10w40 and 10w30 would be indentical when cold. Only issue with 10w30 oils is most of them are "energy conserving" oils with additives that are not good for a wet clutch.
post #6 of 7 (permalink) Old 07-20-2014, 05:08 PM Thread Starter
Trans probs
Yes when I'm riding and go to slow down to stop I always down shift
And here lately it's been goin from 4th straight to neutral some times in other gears
post #7 of 7 (permalink) Old 07-21-2014, 12:48 PM
I doubt seriously it's oil causing it. The clutch job didn't look all that bad. It just sounds like it needs some new plates.
