Is it possible to adjust the shift lever for our feet - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 17 (permalink) Old 07-03-2014, 11:27 PM Thread Starter
Proud Owner of '99 VN 750
furikazashi's Avatar
Only a specific pair of boots will fit between my left foot peg and shift lever making it hard to shift comfortably and not tear my boot toe up in the corner. Is there a way to adjust this or is there alot more transmission work involved in this? I'd like to fit comfortably under my lever
furikazashi is offline
post #2 of 17 (permalink) Old 07-03-2014, 11:39 PM Thread Starter
This is only bolt I see that I may be use to adjust it but will it make it tougher to shift it if I move the lever up a few notches
post #3 of 17 (permalink) Old 07-03-2014, 11:46 PM
emtdon's Avatar
you can take the bolt out and move it up a notch. mark where it was before in case you decide to put it back.
Sent from Motorcycle.com App
2003 kaw vn 750 pushing 40,000 miles.
tp stator
dampers
coil relay mod
other stuff not listed
mustang seat
motorcycle repair at a stealership 1 million bucks, repairs with the help of the Vulcan750 forum priceless.
emtdon is offline
post #4 of 17 (permalink) Old 07-04-2014, 12:13 AM
Chasin' the blacktop
Spencer1's Avatar
X2,,,, fully adjustable but 1 notch makes a lot of difference so work it one notch at a time.
North Georgia
Spencer1 is offline
post #5 of 17 (permalink) Old 07-04-2014, 01:48 AM Thread Starter
thanks alot , any suggestions on what to use for marking? tamper seal is too thick a bead for accuracy
post #6 of 17 (permalink) Old 07-04-2014, 03:43 AM
Just clean the end off with brake cleaner and use a Sharpie/Magic marker. Clean off the marker with break cleaner or alcohol when your done.
post #7 of 17 (permalink) Old 07-04-2014, 11:44 AM
On most Kaw's, and other bikes, there is a dot on the shifter shaft and one on the shifter that are supposed to line up when it is in the factory position. My 1500 has one dot for the toe shifter and one for the heel shifter . I have both of mine one spline off because that is where I like them.
post #8 of 17 (permalink) Old 07-04-2014, 04:58 PM Thread Starter
I adjusted it. Many thanks guys. I will definitely be getting a heel to toe shifter to replace it
post #9 of 17 (permalink) Old 07-04-2014, 08:14 PM
emtdon's Avatar
be careful with a hill toe because the shaft that the shifter goes on isnt very strong and can break easily with to much pressure put on it.
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
post #10 of 17 (permalink) Old 07-05-2014, 04:28 PM Thread Starter
I heard a lot about that too. A friend of mine has a Harley roadking and says his does fine. Any way. To get a stronger shaft or should I be alright? I'm not tough at all with my shifting
