Rear drive leak - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 3 (permalink) Old 06-20-2014, 12:30 PM Thread Starter
aww
Rear drive leak
I have noticed seepage from the rear end on the right side at the bottom. What is the likely cause. I also feel I need to check for adequate lubrication on my front drive splines as well, after reading all of the posts here. Motorcycle is a 2004 VN750 with only 6000 miles, which has been parked alot, which may be part of the problem. Thanks for any advice or suggestions.
aww is offline
post #2 of 3 (permalink) Old 06-20-2014, 12:35 PM
sounds like you have a seal that is leaking in there best bet is to order new seals for the final drive and do a spline lube while your at it
post #3 of 3 (permalink) Old 06-20-2014, 04:21 PM
Ditto on that and here is the link to the final drive gear oil
https://www.vn750.com/forum/showthread.php?t=1113
