False Neutral? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 10 (permalink) Old 05-21-2014, 09:24 PM Thread Starter
False Neutral?
Hey all,
Had my 750 for a little over a year now, putting about 7000 miles on so far. Occasionally (and by that I mean maybe 3 or 4 times in those 7000 miles) I've landed on a false neutral in between 2nd and 3rd gears when upshifting from a start. When it does this, I hear no noises or anything, and if it wasn't for the fact that the neutral light stays off and I'm sure I was upshifting from 2nd it would be indistinguishable from true neutral. When it happens I've been able to just shift right out of it (I usually downshift back to 2nd and try again).
I'm almost positive its because I didn't yank up on the shift lever hard enough each time, but I want to be certain its not the result of wear or something along those lines that might be an indicator of another problem. Also, I've had the Positive Neutral Finder kick me into neutral while attempting to downshift from 2nd to 1st, which is likely unrelated but is still annoying as all get out, and I'm pretty sure its not supposed to do that. Any thoughts?
bluguitar89 is offline
post #2 of 10 (permalink) Old 05-21-2014, 09:36 PM
Originally Posted by bluguitar89 View Post
Hey all,
I agree...it has happened to me also.
Sounds normal ...it also has happened to me.
I've always chalked it up as
hth
post #3 of 10 (permalink) Old 05-21-2014, 10:01 PM
hth
x2
post #4 of 10 (permalink) Old 05-21-2014, 10:19 PM Thread Starter
Good to know! Of course, I'll be monitoring the forum if anyone has anything alarming to add :P
post #5 of 10 (permalink) Old 05-21-2014, 10:24 PM
X3
Shifts need to be deliberate and firm. I missed a few shifts when I got unfocused. The bike sometimes hates going to 1st from 2nd....do to the neutral finder....so as there is nothing farther down after first, double tap 2nd to 1st to make sure....
post #6 of 10 (permalink) Old 05-22-2014, 02:51 PM
interesting....I can honestly say this has NEVER happened on my 2006.
post #7 of 10 (permalink) Old 05-22-2014, 03:10 PM
X2...
wmsonta is offline
post #8 of 10 (permalink) Old 05-22-2014, 03:10 PM
Good, you aren't a lazy shifter then. :P
post #9 of 10 (permalink) Old 05-22-2014, 05:53 PM
:similey_th
post #10 of 10 (permalink) Old 05-23-2014, 02:29 AM
Ndr
I've occasionally had issues hitting neutral when shifting from 1st to 2nd, or 2nd back down to 1st, but I've never heard of issues hitting something like neutral between 2nd and 3rd. That's a bit of a new one to me. In my mind, something is not quite right there.
Ndr is offline
