Noise - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 2 (permalink) Old 04-16-2014, 02:15 AM Thread Starter
Frey
Frey's Avatar
Noise
So I replaced the clutch plates tonight and got on the bike to start it and while in neutral I could feel it pulling forward. I put it in gear and with the clutch in tried to start it again and again felt it pulling. turned off the engine and left it in gear. Pushed it forward and it makes a "popping" noise like an old gear and pulley (click, click, click). Is the transmission gone? Any help.
Asatru Rede of Honor rule 16:
Honor yourself, have pride in yourself, do your best and forgive yourself when you must.
Frey is offline
post #2 of 2 (permalink) Old 04-16-2014, 02:39 AM
Where you been all this time ?....
You either installed improperly (usually the center actuator shaft), or ya need to readjust yer cable....
Did ya place the last plate in one notch over ?....
Willin to bet its 1 of 2 of those 3....prolly not a cable adjustment....
