Drain rear end for spline lube? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 5 (permalink) Old 04-07-2014, 07:30 PM Thread Starter
Do you need to drain the fluid? It would seem odd if you have to lube something if it was immersed in the gear lube.
-Robert
RobertGary1 is offline
post #2 of 5 (permalink) Old 04-07-2014, 07:35 PM
Headbanger/Popes of Hell
ruger's Avatar
you do not need to drain any fluid to lube the splines. check out link below.......
https://www.vn750.com/forum/showthrea...ighlight=fergy
ruger is offline
post #3 of 5 (permalink) Old 04-07-2014, 08:54 PM
yea, once you read thru that thread, you will see that the splines are not bathed in oil.
also, a very light coat of moly should go on the ring of splines that engages the rear wheel. too much here, and it will come out during riding, and generally make a mess of the rear wheel
michiganteddybear is offline
post #4 of 5 (permalink) Old 04-07-2014, 10:30 PM
All great advice given....heed ! LOL
post #5 of 5 (permalink) Old 04-08-2014, 05:45 PM
Just make sure when you take the final drive off the bike you don't lay it on its side or it will start to drain itself. Keep it upright just like it is on the bike.
