Leaking from final drive - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 7 (permalink) Old 02-23-2014, 02:47 PM Thread Starter
Crowley
crowley1027's Avatar
Hey all. Seems the leak I'm trying to fix is behind the final drive bevel. Seems to be leaking from somewhere around the locknut?
The picture shows the area in question. It's all been blown out with compressed air, so I'm waiting for the oil to start leaking again.
Any ideas what it is? How to fix?
Thanks in advance.
crowley1027 is offline
post #2 of 7 (permalink) Old 02-23-2014, 02:54 PM Thread Starter
Crowley
Another view
post #3 of 7 (permalink) Old 02-23-2014, 02:59 PM
Dr. Vulcanstein
jadabull's Avatar
That part is suppose to have oil, your cap is most likely just not seated properly. Just wanted to note that that is the front bevel gear and not the final drive.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #4 of 7 (permalink) Old 02-23-2014, 03:05 PM Thread Starter
Crowley
Okay. It leaked pretty well, spilling probably half quart over a week.
post #5 of 7 (permalink) Old 02-23-2014, 03:07 PM Thread Starter
Crowley
Think I should clean it up and run a thin line of gasket around the mating surface?
post #6 of 7 (permalink) Old 02-23-2014, 03:24 PM Thread Starter
Crowley
Just taped the bevel up after cleaning and clear coated it. Hopefully it'll dry and seal it. The leak was actually coming from between the chrome and black plastic, not the rim of the bevel
post #7 of 7 (permalink) Old 04-10-2014, 06:58 PM
blackomen's Avatar
Mine was leaking between the chrome cap and the black plastic. I separated them, cleaned them up real good and used the oil resistant rtv to seal them up. Has leaked a drop since.
Silvia
MCCT's
Rick's stator
Heated grips
Accessory socket on handlebars
voltmeter
dark side nexen SB802 165/80R15
lubed splines
Tuxedo mod
900 seat
Dyna glide rear shocks
blackomen is offline
