Part numbers for spline seal? Final drive seals? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 8 (permalink) Old 02-19-2014, 03:24 PM Thread Starter
Alpha Geek
Hexadecimus's Avatar
What's the part # for the o-ring that's replaced during spline greasing? It's hard for me to tell from the parts diagrams.
Also what are the seals for the final drive if it's leaking oil? I think one of mine might be leaking but there are a lot of seals on the diagram.
I have my new tires arriving today and want to get this done by the weekend if I can. Thanks.
Hex
Hexadecimus is offline
post #2 of 8 (permalink) Old 02-19-2014, 05:28 PM
Parts found with Part Number: 92055-1044
Description "0" RING,I.D=18.64MM
From some guy on another board "I picked up a plastic container of #17 O-rings at Lowes that worked perfectly. There were aproximately 10 rings and they cost around $2. Should be enough to last 100,000 miles."
post #3 of 8 (permalink) Old 02-19-2014, 05:38 PM
Some riders pick up a Metric Assortment Box of O'rings (a couple hundred ?) for under $6.00....then pick a suitable replacement.
...use of many O'rings over time.
post #4 of 8 (permalink) Old 02-20-2014, 04:49 PM Thread Starter
Alpha Geek
Cheap enough for the genuine part so I'll do that. Any others I should do at the same time before I place my order? Thanks.
post #5 of 8 (permalink) Old 03-19-2014, 10:42 PM
Final Drive Leak by the Front Bevel Gear Case
I hope this isn't a hijack. I have gear oil leaking from the front of the propeller shaft housing. The gear oil level in the final drive has been dropping slowly.
I can't tell by the repair manual diagrams what seal needs to be replaced, what kind it is, O-ring or otherwise, and what the procedure is to replace it.
Anybody know. I have a pretty good assortment of O-rings and even a spare final drive I can throw on if it proves to be time-cosuming to replace the seal.
Its a 93 VN750.
Ray Vick
El Cajon
[email protected]
lrayvick is offline
post #6 of 8 (permalink) Old 03-19-2014, 10:45 PM
Just don't say the word bomb on a plane.lol
post #7 of 8 (permalink) Old 03-19-2014, 11:38 PM
Found the answer waaay down in the forum https://www.vn750.com/forum/showthread.php?t=15189.
I think I will use my spare pumpkin.
lrayvick is offline
post #8 of 8 (permalink) Old 03-22-2014, 09:00 PM Thread Starter
Alpha Geek
Yeah, I was going to say I think the front looked like it needed a special tool. Fortunately mine only leaked out of the vent because I set it down flat. Glad you found your answer. Good luck on the repairs!
