Just finished spline lube - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 6 (permalink) Old 08-23-2013, 02:49 PM Thread Starter
Well I just finished lubing the splines, got her all back together. And then noticed a 1" X 3" spacer on the floor. I guess it goes inside the ring gear on the final drive......Now I have to do it all over again,
smltownr is offline
post #2 of 6 (permalink) Old 08-23-2013, 03:54 PM
And then you will thump your chest and Ar Ar Ar Ar and feel proud of what you have accomplished and you will look upon your work and you will say, "I am man."
post #3 of 6 (permalink) Old 08-23-2013, 04:07 PM
Deviate's Avatar
And just think, you will really know how to take it apart and put it back together! It's like extra practice to get to know your bike even better.
Leave it to me to NOT be fond of something then end up banging it.
Deviate is offline
post #4 of 6 (permalink) Old 08-23-2013, 04:35 PM
it's all part of the learning curve bro!!
hey...at least you realized it before hitting the road....like others have
finish it up and enjoy the rewards
post #5 of 6 (permalink) Old 08-23-2013, 04:47 PM
You would have felt a really bad grinding noise if that was left out. Be glad you found it before you damaged something.
post #6 of 6 (permalink) Old 08-25-2013, 05:17 PM Thread Starter
The second time took only 30 minutes...I did not need to do a lot of things previously. I only removed the right lower shock mount, centerstand, with ratchet straps to compress shocks and removed axle with wrench not socket. I think I could do a complete lube in a hour now. Yup live and learn
smltownr is offline
