loud grinding noise when releasing the clutch - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 10 (permalink) Old 08-21-2013, 01:41 PM Thread Starter
When I put the bike in gear and begin releasing the clutch it inches forward but when I try to take of it grinds real load and doesn't want to move forward. Is this a clutch or a trans issue or something else
Dhankins is offline
post #2 of 10 (permalink) Old 08-21-2013, 01:55 PM
R/R = Relocated Redneck
Jakzen's Avatar
Most likely a clutch issue... Might be springs, but if you're going to crack it open, replace all the parts.
Mods
Voltmeter/clock/temperature gauge
HD Electra Glide Fairing
Earshave/Coastered/CA emissions - gone...
Nightster seat
Tombstone taillight
Drag specialties turn signals relocated
Sportster progressive shocks... Dropped rear 1 1/2"
Progressive Fork Springs dropped front 1"
NGK plug wires and iridium plugs
Coil Relay Mod
Paint
ACCT to MCCT
Honda Rebel luggage rack
VN800 Handlebars & controls
Screamin Eagle mufflers
F&S Engine Guard & Kury highway pegs
Jakzen is offline
post #3 of 10 (permalink) Old 08-21-2013, 02:18 PM Thread Starter
Wanted to make sure that was the likely issue before I started ordering parts and taking it apart, I appreciate it, Hope that's all it is
Dhankins is offline
post #4 of 10 (permalink) Old 08-21-2013, 02:41 PM
check your splines too before ordering parts. the ones from the drive shaft to the final drive.
michiganteddybear is offline
post #5 of 10 (permalink) Old 08-21-2013, 04:06 PM
Dude, your splines are shot. When mine blew, the bike would lurch forward then make a horrible grinding noise. The grinding would stop once clutch lever was pulled in. You can verify this by putting the bike in gear on center stand and feeling the rear hub and driveshaft areas. Might as well pull rear off while you are at it and check the final drive splines and coupler.
Good luck.
post #6 of 10 (permalink) Old 08-21-2013, 09:34 PM Thread Starter
Pulled the wheel off it is the coupling attached to the drive shaft thanks for all the advices helped a lot, can I get just the coupling or do I need a whole new shaft?
Dhankins is offline
post #7 of 10 (permalink) Old 08-21-2013, 11:10 PM
You will need both coupler and final drive. The shaft doesn't usually fail. The splines may be there on final drive, but working with a new coupler may cause eventual failure. Sadly, the final drive runs for $900 new. If you can find a good used one, go that route. Get some Honda Moly 60 to lube the splines and coupler. The lack of lube is the reason your splines failed.
Good luck!
post #8 of 10 (permalink) Old 08-22-2013, 02:05 AM
Spline lubes have to be taken seriously on the Vulcan 750. While many other bikes have this problem, including BMW, the Vulcan 750 seems to be the worst. So many have failed that the supply of good used ones should probably be drying up by now. Dealers and online parts places have new final drives in stock, and may have for a very long time, considering what they cost. Or at some point they may cut the price in half to get rid of them. But how many Vulcan 750s will still be in existence by then?
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #9 of 10 (permalink) Old 08-22-2013, 10:38 AM Thread Starter
What is a good site for parts cant find the coupler on ebay or any web searches
Dhankins is offline
post #10 of 10 (permalink) Old 08-22-2013, 11:57 AM
Post Here's a few on Ebay for fair prices
If I can't find something on there, I change the search terms around and that helps sometimes.
http://www.ebay.com/itm/1990-Kawasak...6bf87a&vxp=mtr
http://www.ebay.com/itm/KAWASAKI-VUL...e39005&vxp=mtr
http://www.ebay.com/itm/1994-KAWASAK...36ceb7&vxp=mtr
http://www.ebay.com/itm/1990-Kawasak...0fa2fb&vxp=mtr
http://www.ebay.com/itm/Kawasaki-Vul...3bae90&vxp=mtr
http://www.ebay.com/itm/drive-shaft-...fef9f6&vxp=mtr
Ebay search: vn750 driveshaft
http://www.ebay.com/sch/Motorcycle-P...eshaft&_sop=15
