Reading spline lube sticky - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 13 (permalink) Old 08-15-2013, 07:34 PM Thread Starter
Read through the aforementioned sticky. I understand it all, untill the end addition, to moly the hub to wheel gears. I looked at my hub and it shows to use 80 or 90 SAE gear oil, and seems to have a fill plug. Also I am replacing tires and I looked up the rear should be a 130/100x16. What is on it is a 150/100x15 I can understand changing the ratio, but does the difference in wheel diameter mean a aftermarket wheel? Yes 2 questions in one posting, new to this model.
smltownr is offline
post #2 of 13 (permalink) Old 08-15-2013, 10:01 PM
Stock tire is a 150/90 X 15 , not sure where you got 16" from.
Not sure what addition you are talking about. But yes, the final drive uses gear oil...most use synthetic oil in there. Mobil One 75/120....whatever.
post #3 of 13 (permalink) Old 08-15-2013, 10:10 PM
The gear oil is a separate process from moly of the spline. When you separate the wheel from the spline gear housing, you will see a gear. Just take a qtip and splotch moly on the teeth.
The gear oil thing you can do without taking anything off.
Just start taking things apart according to the versus and your eyes will open :-)
post #4 of 13 (permalink) Old 08-15-2013, 11:34 PM
Aside from the gear oil, there are 3 places that need to be lubed with a moly PASTE. At the front ends of the drive shaft, where the U joint connects to the engine output shaft, at the rear of the shaft, where the coupler connects to the final drive gearcase input shaft, and the pinion splines on the BACK of the final drive gearcase, that engage with the rear wheel.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #5 of 13 (permalink) Old 08-16-2013, 10:24 AM
Yes all of the technical stuff he just said and the front u-joint thingy is sprayed with white lithium greasy stuff.
post #6 of 13 (permalink) Old 08-16-2013, 10:38 AM
Originally Posted by goofyfoot2001 View Post
yes all of the technical stuff he just said and the front u-joint thingy is sprayed with white lithium greasy stuff.
moly !
post #7 of 13 (permalink) Old 08-16-2013, 11:07 AM
Originally Posted by WilliamTech View Post
moly !
WHITE LITHIUM!!!!
Using moly is pointless and a waste of moly paste. But, hey, you can do whatever makes you happy.
post #8 of 13 (permalink) Old 08-16-2013, 11:23 AM
WHITE LITHIUM!!!!
reading the title of the thread, ...i thought we were speaking splines here.... my bad.
post #9 of 13 (permalink) Old 08-16-2013, 11:25 AM
R/R = Relocated Redneck
Jakzen's Avatar
moly !
X2 lithium grease doesn't stand up to heat.
I used the moly on a few additional things as well including axle shafts, Speedo drive and the internals on the gas cap. It's a little messy, but useful. Add far as using a qtip to apply it to the splines, that may very well be good enough, but it wasn't fun getting the oversized tire back on & I'd just as soon not have to do it again for a long while. On the splines, I packed it around the gear and put a thin layer on the contact surfaces. Yes it was more than necessary and some excess got slung on the wheel during the first three rides after doing the work. Degreaser and rags are a lot cheaper than a final drive...
Mods
Voltmeter/clock/temperature gauge
HD Electra Glide Fairing
Earshave/Coastered/CA emissions - gone...
Nightster seat
Tombstone taillight
Drag specialties turn signals relocated
Sportster progressive shocks... Dropped rear 1 1/2"
Progressive Fork Springs dropped front 1"
NGK plug wires and iridium plugs
Coil Relay Mod
Paint
ACCT to MCCT
Honda Rebel luggage rack
VN800 Handlebars & controls
Screamin Eagle mufflers
F&S Engine Guard & Kury highway pegs
Jakzen is offline
post #10 of 13 (permalink) Old 08-16-2013, 11:55 AM
Jakzen's Avatar
LITHIUM!!!
Keeping crazy people on the streets since......
Mods
Nightster seat
Tombstone taillight
Coil Relay Mod
Paint
ACCT to MCCT
Jakzen is offline
