Fluid on rear end and rim - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 11 (permalink) Old 08-08-2013, 08:42 PM Thread Starter
Hippo Daddy's Avatar
Thoughts on the cause? Simple or difficult repair?
2001 Vulcan 750. 9300 miles.
ID:	9970   Click image for larger version
Hippo Daddy is offline
post #2 of 11 (permalink) Old 08-08-2013, 08:55 PM
the seal in the final could be leaking or it could just be that it is slinging extra grease off
either way not that hard of a fix and fairly cheap too
post #3 of 11 (permalink) Old 08-08-2013, 09:01 PM
I have similar on occasion..
some bonehead mechanic way over greased the splines between the final drive and rear wheel.. when it gets hot enough, it slings/runs out
michiganteddybear is offline
post #4 of 11 (permalink) Old 08-09-2013, 10:28 AM Thread Starter
Directions on replacing seal? Simple? Time involved. Parts cost? Never tried something like this but very willing.
Thank you.
post #5 of 11 (permalink) Old 08-09-2013, 10:40 AM
...involves pulling the rear wheel, I believe involves only 2 seals total... a few bucks.
Clean the grease/Moly off, ...seals may be ok after all excess has been flung off.
....just a thought.
post #6 of 11 (permalink) Old 08-09-2013, 11:35 AM
R/R = Relocated Redneck
Jakzen's Avatar
I'm one of those bonehead's. I greased mine last weekend and would rather have too much vs not enough. Got plenty of rags....
If it was gear oil from the seals, I would think that it would run down the wheel whenever the bike was parked. Mine looked a lot like that when I got it last year. I cleaned it up and it wasn't a problem after that.
Mods
Voltmeter/clock/temperature gauge
HD Electra Glide Fairing
Earshave/Coastered/CA emissions - gone...
Nightster seat
Tombstone taillight
Drag specialties turn signals relocated
Sportster progressive shocks... Dropped rear 1 1/2"
Progressive Fork Springs dropped front 1"
NGK plug wires and iridium plugs
Coil Relay Mod
Paint
ACCT to MCCT
Honda Rebel luggage rack
VN800 Handlebars & controls
Screamin Eagle mufflers
F&S Engine Guard & Kury highway pegs
Jakzen is offline
post #7 of 11 (permalink) Old 08-09-2013, 11:56 AM
Mine didnt 'run' until I got the rear end good and hot from a longer ride. I stopped to give the arse a break, and it had dripped at that time.
there needs to be very little lube on the splines (final drive to wheel), as there is very little if any real movement there. mostly there to keep stuff from rusting together probably
post #8 of 11 (permalink) Old 08-09-2013, 12:19 PM
mine does this after riding in the rain....no big deal.
If it happens all the time I would keep an eye on the fluid level of the rear end.
Keep wiping it down...you don't need oil on the tire...that could be dangerous.
post #9 of 11 (permalink) Old 08-13-2013, 10:22 PM
Could be either a seal leaking slightly, or excess grease on the splines. My rear wheel has looked like that almost since I got the bike new. I clean it up once in a while, but it just comes back. I have not noticed the final drive oil level being low. I did do a spline lube less than a week after bringing the new bike home. Good thing too, as they were completely dry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #10 of 11 (permalink) Old 08-21-2013, 10:45 AM
geezyrider's Avatar
Y'all may think me a little whacko, but I stuck a band aid over the square hole at the bottom of the final drive. After a long ride there was still black stuff on the wheel rim and tire. "BUT", none on the band aid, proving that the ring gear oil seal was not leaking and that it was coming from the wheel side. Ie: overgreasing of the ring gear and wheel splines.
geezyrider is offline
