No Power to Back Tire - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 45 (permalink) Old 07-27-2013, 09:26 PM Thread Starter
So...I was out riding all day today and on the way back to my house, every time I would let go of the throttle i would here a loud "click" like something was getting caught. I stopped to look at the bike and saw/heard nothing. Went to drive away and the problem was gone. A couple miles down the road I was accelerating after a stop sign and all of a sudden lost ALL power to the rear tire. I can turn the bike on and the engine runs like a champ. Once i shift into first gear, I hear a bunch of clatter coming from either the back hub or where the shaft connects into the engine. This clatter happens regardless if the clutch is in or out and the sound gets louder with more gas. No power comes to the rear tire all i get is the clatter instead.
Not sure what to do. Fix, sell, cry? lol
Any help is appreciated.
Dan Prez is offline
post #2 of 45 (permalink) Old 07-27-2013, 10:04 PM
That sounds like your drive shaft splines have failed. This happens if they were not lubricated properly.
They're not really difficult to replace, but can run $200-$250. I have one I can sell for $200+shipping that's in good shape. I also see a few for $250 on eBay as well.
Here is a write-up on replacement/maintenance of it. https://www.vn750.com/forum/showthread.php?t=17274
post #3 of 45 (permalink) Old 07-27-2013, 10:11 PM Thread Starter
I was thinking that, but why would the chatter still occur even if the clutch is pulled in?
Dan Prez is offline
post #4 of 45 (permalink) Old 07-27-2013, 10:19 PM
You still have some clutch drag that turn the gears.
post #5 of 45 (permalink) Old 07-27-2013, 10:20 PM
Yes, there is always a little tension on the drive train even with the clutch pulled in. Your drive splines are shot.....$10 worth of grease and 1/2 hr. would have kept that from happening. Sorry for the news.
post #6 of 45 (permalink) Old 07-28-2013, 12:28 AM
2000 VN 750 Senior Member
First thing to do is to take some time to read the Vulcan Verses. You have been a memaber since 2011 and with only 29 posts. You need to take advantage of the information offered here to avoid these costly problems. The fact that you could have read about the potential problem and found out how to avoid it a long time ago saving time and money is what you should be crying about. Live and learn but I hope you do spend some time reading the ten things you should know soon and help yourself from these problems.The VN 750 is a great bike but like anything it takes a little maintenance to keep it running correctly. $10 worth of grease that will last multiple spline upkeeps and a half to one hour of your time vs. what you have now.........priceless.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #7 of 45 (permalink) Old 07-28-2013, 01:05 AM
Not if they were already on their way out it wouldn't. Don't judge what you don't know.
Just a heads up OP, expect to be corned like some helpless animal by other members because you didn't take care of your splines correctly.
post #8 of 45 (permalink) Old 07-28-2013, 08:10 AM Thread Starter
Just so you all know who think i haven't read any posts. I greased the splines two years ago the second week I bought the bike. Used Honda Moly to grease it. That's where my confusion is. With that being said, do we still think its the splines?
Dan
Dan Prez is offline
post #9 of 45 (permalink) Old 07-28-2013, 09:16 AM
Dan
Yes, mine failed under near identical conditions; however, mine were never lubed.
Get that tire off and you'll know for certain.
post #10 of 45 (permalink) Old 07-28-2013, 09:36 AM
Headbanger/Popes of Hell
ruger's Avatar
the problem is not what DP did or didn't do, it's what is he going to do! no use crying over spilled milk. you need to pull the rear wheel and see if in fact, if that is the problem (splines). I too, believe it is.
so first things first. pull the wheel. then if the is in fact the problem, do what you have to do to get the bike back on the road. there are more than enough members here to help you out. and what I mean by "help", is not bashing the guy for what he didn't do to get to this point!
ruger is online now
