faster vulcan? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 27 (permalink) Old 06-28-2013, 10:53 PM Thread Starter
faster vulcan?
While waiting for my motorcycle parts, in between a soffet R&R, adjusting my bicycle and mowing 1 1/2 a. today, I decided to put my new Shinko rear tire on. Check splines, etc.
The last 4 motorcycles I have owned were shaft drive. The output and final drive on the VN are large. I would guess they could take 3x 60hp. Had to be designed for parts compatibility with other bikes. So I checked some parts numbers.
I tried the search, nothing came up. Has anybody tried to adapt say a 1500 final drive to a VN? Or other Kawasaki final drives?
As I have walked around machinist's and machine shop almost all my life, I am tempted to get involved on a on/off basis. I have a full set of machinist tools.
What size rear tire, what rpm's at 70mph and what is the approximate distance between the swing arm axle mounting on a 1500?
Has this been attempted before? If so, what was the thread about so it can be searched?
wmsonta is offline
post #2 of 27 (permalink) Old 06-29-2013, 02:00 AM
I have no clue but the last bubf I saw had the same size tires as my 750 and had cast rims I would say they would be really close but I. Have. No clue about the bevel gear but then again I would say to get a hhigher top speed you would really have to work that into the trans if you want to see a noticable differance
post #3 of 27 (permalink) Old 06-29-2013, 02:24 AM
I had the opportunity to look at a 1500final drive, and IMO, I believe it would mate up to our tire just fine. However, I've heard that the 1500 FD has a different ration to help keep RPM's down. I wanted to mate a 1500 rear tire to the 750's final drive to get a different looking rear rim and different tire size possibilities, didn't get the chance; but, I believe wheels and FD's are interchangeable between the 2 bikes. I know for certain, the front tire on a 1500 is too wide to fit our skinny forks.
post #4 of 27 (permalink) Old 06-29-2013, 10:46 AM Thread Starter
blaz, your thread on the disc brakes came up in my search.
new rider, my goal would be to reduce rpm's. Even though I have 'over driven' Fuller Roadranger's 30 yrs ago, the design made it possible. I do not believe changing the transmission to be economically feasible. At first glimpse the rear end ratio appears easier than a lot of my endeavors.
I would need an accurate torque curve for the VN, and an account of the available ratio's. By necessity all transmission gear speeds will increase the same.
By necessity this would have to be a 'part time' endeavor, and I will become busier than I am.
Thanks for the replies.
wmsonta is offline
post #5 of 27 (permalink) Old 06-29-2013, 10:53 PM Thread Starter
Good idea, no practical application.
Even though a 1500 has the same bearings and coupler, it has a ring/pinion of 36/10. VN 750 is 37/10. Not enough change for me to go any further.
wmsonta is offline
post #6 of 27 (permalink) Old 06-29-2013, 10:56 PM
faster vulcan?
With the preliminary's I am reading....I doubt it !
post #7 of 27 (permalink) Old 06-29-2013, 11:08 PM Thread Starter
Yeah William, I am done. With a rated peak torque @ 3000 rpm, I would have bet on a taller ratio. Makes less sense to wind a 1500 that tight than it does a 750.
wmsonta is offline
post #8 of 27 (permalink) Old 06-29-2013, 11:16 PM
sounds logical..... you would know best.
post #9 of 27 (permalink) Old 06-30-2013, 10:03 PM
Vinny Kolouzo (sp ?) put a larger diameter rear wheel on his....that would lower your rpms at the same speed, right ?...lots of room to put a bigger rear wheel and tire on (if not Sportster 11.5" shocks would raise it enough)....you could then get longer upper front tubes to compensate.......check with Vin as to what he used....lotta work for what its worth, IMO...
post #10 of 27 (permalink) Old 06-30-2013, 11:26 PM Thread Starter
Wolfie, I would want 10% rpm drop or I wouldn't mess with it. The 1500 I checked out should have had a taller gear, unfortunately it does not. The 750 has a 67% higher torque peak than the 1500. 3000 vs 5000. Ring and pinions are virtually the same.
wmsonta is offline
