should I be able to shift? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 18 (permalink) Old 06-26-2013, 11:50 AM Thread Starter
BeeSea's Avatar
I am rebuilding my case and after watching Roaches videos I made sure the gears were in neutral when I put the halves back together. Someone said before I go too far on putting everything back together I should make sure I can shift through all the gears. Well I put that theory to test and I can shift into first and then back into nuetral but then I can only shift into 2nd...
Did I do something wrong inside and need to tear it apart or is it because the bike is not running that it doesn't shift up any higher than second gear? Thanks
BeeSea
1986 750 Vulcan
Relocate R/R to side cover
Re-did the engine
from the case up.(And it runs)
YOU CAN TOO!
BeeSea is offline
post #2 of 18 (permalink) Old 06-26-2013, 12:01 PM
Can you rock the gearing some way...??? I'm thinking you have everything out of the bike, and if you can rock the gearing back & forth and shift you are probably OK...JMO...
There are others on here that know much more than me...lol...
post #3 of 18 (permalink) Old 06-26-2013, 12:07 PM Thread Starter
BeeSea's Avatar
yeah everything was dismantled and I put the halves back together and was putting on chain guides when someone suggested I make sure it could shift-if it don't shift on the bench they said it wont shift on the bike...
BeeSea
1986 750 Vulcan
Re-did the engine
YOU CAN TOO!
BeeSea is offline
post #4 of 18 (permalink) Old 06-26-2013, 12:09 PM Thread Starter
BeeSea's Avatar
oh and I am just doing it by the foot lever, I dont have anything connected to 'pull in the clutch' like the hand grip does
BeeSea
1986 750 Vulcan
Re-did the engine
YOU CAN TOO!
BeeSea is offline
post #5 of 18 (permalink) Old 06-26-2013, 12:37 PM
If it is a Vulcan, you should only be able to shift between !st and neutral on the bench. That Kawasaki positive neutral finder thingy.
wmsonta is offline
post #6 of 18 (permalink) Old 06-26-2013, 01:03 PM Thread Starter
BeeSea's Avatar
yes it is a vn750 kawasaki
so is it bad that i can go into 2nd?
BeeSea
1986 750 Vulcan
Re-did the engine
YOU CAN TOO!
BeeSea is offline
post #7 of 18 (permalink) Old 06-26-2013, 02:42 PM
I think you're fine.
post #8 of 18 (permalink) Old 06-26-2013, 03:07 PM Thread Starter
BeeSea's Avatar
oh good then I am carrying on in putting it back together....thanks!!!
BeeSea
1986 750 Vulcan
Re-did the engine
YOU CAN TOO!
BeeSea is offline
post #9 of 18 (permalink) Old 07-31-2013, 04:22 PM
If I remember correctly, there are 3 little balls in there, like ball bearings. That is the dreaded positive neutral finder. If it were mine, and I had it tore down that far, I would leave those out. Kawasaki is the only one that uses such a setup, and I have no idea why. It seems like they caused a problem trying to come up with an answer to a problem that didn't exist.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #10 of 18 (permalink) Old 08-01-2013, 07:28 AM
gibbo's Avatar
When selecting a gear one is attempting to mesh one set of "dog" teeth sideways into a corresponding set of slots in order to lock two gear wheels together. with everything stationary one cannot know if the dogs line up with the teeth, you need to turn the output shaft (big splined bit that drives the bevel box, or if bevel box still fitted then the bit that drives the drive shaft), or the input shaft (engine) to produce relative motion in the gears one is trying to mesh. Simply, turn the output shaft by hand while trying to select gears. this will allow the dog teeth to slot into their respective slots. Since you can already find second it would seem the neutral finder is not an issue for you.
One can never have too many alternative forms of transport.
gibbo is offline
