Final Drive - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 5 (permalink) Old 06-22-2013, 12:02 AM Thread Starter
geezyrider's Avatar
Final Drive
Not trusting what the tech at the dealer did, I removed the rear wheel and the final drive. He did replace the pinion gear/spline shaft. but didn't change out the gear oil. Go Figure! I drained and replaced the gear oil. Will run it a few days and change it out again. The output seal in the final drive is good. And yes, when the tech re-installed everything he overgreased the outlput spline drive and I will have some grease coming down for a while. (I didn't want to remove any of the grease. But I installed a big band aid at the weep hole to catch any grease coming down. And he also left several pieces of installation hardware off the bike. Oh, and BTW, one more thing, since I was in the mood for checking things, I pulled the right muffler and it has been gutted out, which explains the more than louder non stock exhaust.
geezyrider is offline
post #2 of 5 (permalink) Old 06-22-2013, 05:27 AM
how many final drive threads are you going to start... keep it all in one place bud. if you feel ya been mistreated by the stealership, take it back, or just deal with it
post #3 of 5 (permalink) Old 06-22-2013, 08:16 PM Thread Starter
geezyrider's Avatar
It is my final post on the subject. However, if and when you reach the age of 81 and can still handle a motorcycle as well as I can, why then I may take your unsolicited opinion into consideration.
post #4 of 5 (permalink) Old 06-23-2013, 02:32 PM
gibbo's Avatar
I'm only 64 and hope to be able to still manage a bike at your age, you give me renewed hope. Cheers, have a good week.
One can never have too many alternative forms of transport.
gibbo is offline
post #5 of 5 (permalink) Old 06-23-2013, 02:38 PM
In the future please try to keep related topics in the same thread. This could have been a continuation of your other one.
It's for forum organization, and to help other members search for information more quickly. If a single topic is kept to a single forum thread, then the information is more easily available for the other members. The old posts here are like a treasure trove of information.
No offence, but your age is not a shield to hide behind any time a moderator makes a suggestion to you. He is a moderator, so it was not unsolicited opinion, but an official suggestion.
