Clutch adjust - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 8 (permalink) Old 05-22-2013, 12:57 AM Thread Starter
geezyrider's Avatar
Clutch adjust
I purchased my VN-750 today. And have yet to get a service manual. The clutch lever goes almost all the way out before engaging. (9K miles) It doesnt slip once engaged so I believe it only needs adjust. I knew how to adjust the clutch on my old 454LTD but the VN-750 set up down at the clutch housing looks a little different. Can anyone set me right? I looked on the forum for a manual to no avail.
geezyrider is offline
post #2 of 8 (permalink) Old 05-22-2013, 01:05 AM
I believe that's how it supposed to work. The clutch only engages at the last bit of lever. You really only need a nickels width of gap between the lever and housing. There is a course adjuster behind the lever and a fine adjuster further down by the vertical frame. Use the adjuster at the clutch lever to get the aprox. gap and test it out. It has a larger locking wheel-net which needs to be loosened before the smaller screw part can move in.
post #3 of 8 (permalink) Old 05-22-2013, 01:51 AM
Okiebezer's Avatar
Check this thread, maybe it will help.
https://www.vn750.com/forum/showthrea...tch+adjustment.
Malibu Shades windscreen, headlight visor, custom dashboard with voltmeter and clock, luggage rack, extended backrest, Viking saddlebags and toolbag, Wingerline engine guard with foot pads, light bar with halogen bulbs, Hardley Sportster muffs with crossover, homemade coasters, earshave with K&N pods, 142/42 jets with 2 shims each needle, MCCT's, AGM battery, coil relay mod, Iridiums with yellow NGK plug wires, relocated R/R, WOLO air horn, VN750.com chrome radiator guard
Okiebezer is offline
post #4 of 8 (permalink) Old 05-22-2013, 02:57 PM
you can download a manual HERE
post #5 of 8 (permalink) Old 05-22-2013, 03:54 PM
For the manual, down load it in my signature.
It's better than TOC's as it is chaptered so you can find what your looking for.
post #6 of 8 (permalink) Old 05-22-2013, 04:31 PM
what he said!! lol
I was trying to find your link to post it, but got busy here at work and posted the TOC one cuz I was lazy.....yours is MUCH better!!
post #7 of 8 (permalink) Old 05-22-2013, 05:12 PM
I have an 800. I keep the clutch gap at about 3/8" to 3/4" My clutch will begin to engage when I get 3/4 pulled in with clutch handle.
It will engage more and more as I get closer to fully out.
If your clutch only engages in the last little bit of throw, then I think you have a problem, as that is not how it is 'supposed to be'. Remember 'friction zone' from all the riding courses that we all take hehe.
kenny
Merc
2000 Vulcan Drifter 800
Roadhouse classic 2 > 1 exhaust
Okie Smokie intake config
Changed jets
52K miles or so, always going up
Corbin Seat
Painted flat black winter '12
Mercury is offline
post #8 of 8 (permalink) Old 05-23-2013, 07:42 AM
Not sure the issue. Every mechinical clutch on Every bike I've ever seen adjusts the same way. You don't need a freaking manual if you've worked on other bikes...
