Gear oil recommendation for final drive - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 5 (permalink) Old 05-11-2013, 05:54 PM Thread Starter
Captive New Yorker....
peterherrm's Avatar
What gear oil do you guys recommend for the final drive. I'm thinking its time I changed mine. Is there a particular brand people use over another?
Pete Herrmann
Bought 4/2011 28k Miles,
New Rick's Motorsports R/R
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
peterherrm is offline
post #2 of 5 (permalink) Old 05-11-2013, 05:55 PM
What does it say on the final drive? Just use SAE 90 oil.
post #3 of 5 (permalink) Old 05-11-2013, 06:42 PM
JM2001's Avatar
The manual calls for 90 weight over 41 degrees and 80 weight under 41 degrees. I have used all the high price stuff and now only use SuperTech 75/90. Works well.
http://www.walmart.com/ip/Super-Tech...Quart/16795248
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 5 (permalink) Old 05-12-2013, 01:06 AM
AmsOil brand gets my vote.
post #5 of 5 (permalink) Old 05-12-2013, 07:19 AM Thread Starter
peterherrm's Avatar
Great, thanks!'
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
