Final drive oil change - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 12 (permalink) Old 04-16-2013, 10:06 PM Thread Starter
So since I put the new final drive on the 2002 I really only took a few short trips to get the feel of the bike. I did notice when I got off the throttle and it started to decelerate that there seemed to be a little whine in the rear. As soon as you give it just a little throttle it goes away. I pulled the inspection plug out tonight and didn't feel any fluid so I pulled the plug and drained what was there and pumped in new Valvoline Synthetic Blend 80W90 gear oil. I plan on riding to work in the morning for the 1st time on it, so I'm hoping that helps. I'll report back in the morning.
post #2 of 12 (permalink) Old 04-17-2013, 01:52 AM
sparkingdogg's Avatar
if there is a little whine in the rear, you could always add some cheese in the front
2003 VN1500 Nomad FI Bagger
2004 KLX400SR Dual Sport light adv bike
1969 CB750 K0 sand cast #1767
couple of nice GL650 Silver Wing Interstates, one with hack
2 and 4 stroke dirt bikes
other vintage stuff back in the corner
sparkingdogg is offline
post #3 of 12 (permalink) Old 04-17-2013, 03:02 AM
SlowBox's Avatar
Normally a rear end whine is from setting the backlash too loose. Idk if it's even adjustable on our bikes...
SlowBox is offline
post #4 of 12 (permalink) Old 04-17-2013, 08:38 AM
JM2001's Avatar
When filling the rear drive oil you should add some oil then rotate the tire. The oil will disappear allowing you to add more oil. Repeat the process until the rear drive is full of oil.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 12 (permalink) Old 04-17-2013, 10:49 AM Thread Starter
I'll check it again when I get home, seems like it's probably normal noise. I didn't hear it that much on my 94 because the exhuast was louder.
post #6 of 12 (permalink) Old 04-22-2013, 07:02 PM
Holzcman ,new rider
be careful when you tighten the 17mm cap
Don't tighten it too tight I broke mine today.wasn't expecting a cap made of plastic!!!
Holzcman is offline
post #7 of 12 (permalink) Old 04-22-2013, 08:39 PM
It should be alloy....lol
post #8 of 12 (permalink) Old 04-22-2013, 08:55 PM
Holzcman ,new rider
whatever it is made of i just ordered one plus a few other "o" rings that i needed.
Holzcman is offline
post #9 of 12 (permalink) Old 04-22-2013, 10:38 PM
Mine is aluminum, but very soft and very thin. Would break very easily. I put a piece of blue paper/cloth shop towel between the plug and the wrench to keep from rounding off the corners, and just slightly snug it up. Bike should be on the centerstand or it will not get completely full. Put some rags under it. It is messy getting spilled gear oil off the rear wheel and tire.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #10 of 12 (permalink) Old 04-23-2013, 12:24 AM Thread Starter
I still have the old final drive and was wondering what to do with it. I'll probably pull that plug off in case I need it in the future. Not sure what to do with the rest of it other than scrapping it. The gear's shot so it's pretty much worthless from what I understand.
