Greasing U joint - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 6 (permalink) Old 03-28-2013, 02:38 PM Thread Starter
Amsoil Man's Avatar
Greasing U joint
ANybody find a way to grease U joint on drive shaft.Joint cannot be life long sealed grease.
Thanks
Amsoil man
Pick ups reset
Splines lubed
Kenda Kruz tires 110Frt. / 170 rear
Custom saddle seat
Backrest
1500 classic rear fender
Cobra slants /Custom Made turndowns
Diamond Plate Buffalo Leather Bags
Throttle lock
Front bearings repacked
Front shock oil replaced
Led bulbs
Amp meter
Running Boards
Dial A Jet Carb settings
Gremlin Bell (front mount)
Fully Lubed with Amsoil Lubricants
Trailer hitch / Hidden
Your Local AMSOIL Connection! Cell#989-329-1225
Amsoil Man is offline
post #2 of 6 (permalink) Old 03-28-2013, 04:54 PM
JM2001's Avatar
Thanks
Amsoil man
I use this lithium grease spray
http://www.motosport.com/dirtbike/pr...segment=badger
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 6 (permalink) Old 03-28-2013, 05:37 PM
There is no way to lube the u-joint. You can spray lube on it, but it is not lubeing any thing inside the joint itself.
post #4 of 6 (permalink) Old 03-28-2013, 10:14 PM
Note, I never done it on a VN, but if it was assembled, it can be disassembled...Im guessing its a pin type bearing and gets pressed in at the factory. It can therefore be pressed out...once thats done (dont lose the pins) can be greased from the inside. Almost willing to bet, a comparable U-joint could be found that has a tapped in fitting like modern cars do. Ir even tapped for a fitting.
Funny too, because I been thinking about that recently.
post #5 of 6 (permalink) Old 03-28-2013, 11:12 PM
I havent taken a close look at it, but I believe that it is a sealed u-joint. I see them on the 18 wheelers on the steering shaft and on the drive shaft too.
post #6 of 6 (permalink) Old 03-29-2013, 01:56 AM
this is one of those "if it ain't broke don't fix it things". If you must take it apart,go look at the kawasaki Praire 400 ATV rear diveshaft U-joint and see if yours measures the same,It is pretty close and Kaw sells it separately unlike the one for a bike driveshaft. I know it is a direct replacement for the 1500/1600 although they won't tell you that and they look to be the same size.
