Drive shaft leak front end - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 7 (permalink) Old 12-30-2012, 01:10 AM Thread Starter
Steve
350ernie2's Avatar
Some advice please. There a little oil is dripping from the from of the drive shaft at the front at the bottom of the rubber. I pulled back the rubber and there does not seem to be oil in there, just the white spray on grease. Its just a few drops when I stop and appear to be oil, not grease. Any ideas ?
Steven
Steve
VN750
KH500
Ducati 350sss
350ernie2 is offline
post #2 of 7 (permalink) Old 12-30-2012, 09:00 AM
you are talking about the universal joint just behind the transmission....there is no oil in that area...it should be dry other than some grease.
It may be that you have a small leak from the crankcase that is working it's way down there before it drips. The seal for the output shaft from the case might have a leak.....or the bevel gear is leaking.
post #3 of 7 (permalink) Old 01-02-2013, 04:11 AM Thread Starter
Steve
350ernie2's Avatar
Thanks for the information . I guess I will need to take teh draft drive off to get in there and take a real good look. Its been happening for a little while. I just top it up with 500 mls of oil very 3000kms.
I cant really afford to get it fixed, so I might just persists unless tehre is something I can do myself.
Steve
VN750
KH500
Ducati 350sss
post #4 of 7 (permalink) Old 01-02-2013, 07:00 AM Thread Starter
Steve
350ernie2's Avatar
Steve
VN750
KH500
Ducati 350sss
post #5 of 7 (permalink) Old 01-02-2013, 07:45 AM
Might also be the front bevel case leaking a bit of oil. It does have an oil line going to it.
post #6 of 7 (permalink) Old 01-02-2013, 09:55 AM
I'm also wonderin if it is gettin blown back, and when you park on the side stand drippin down...??? Clean it up underneath good and recheck, just to see if it might be comin from somewhere else, even possibly from the other small oil drain plug... Just a WAG...
post #7 of 7 (permalink) Old 01-08-2013, 09:06 PM Thread Starter
Steve
350ernie2's Avatar
I had a good look and there does not appear to be any blow back from under the motor, it looks clean. Its just a few drops from the rubber at the bottom of the front of the shaft. I took a photo, its hard to tell as its upside down, ie taken from the ground looking up. The oil is just at the bottom of the rubber. I noticed it only happens in really hot weather. It was 105 (39 c) when it first started to happen. The temp guauge was just on the red. It does not like hot weather but it kept on going.
Steve
VN750
KH500
Ducati 350sss
