Can we ever say it enough, lube the splines! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 7 (permalink) Old 10-26-2012, 09:38 PM Thread Starter
Well I got the newest addition to the family running tonight with a replacement final drive and coupling. It was really hard to believe this thing ever had grease in it. Seriously LUBE YOUR SPLINES!!!!!
post #2 of 7 (permalink) Old 10-26-2012, 09:44 PM
Youngster
1stVulcan's Avatar
wow thats so bad! Did it still go into gear?
1990 VN750 Red and Black
Bought on 6/30/2012 w/ 13,230 miles
At ~20,000
To Do List: Paint Front Rim, Acct- mcct mod
Done: Adjusted Float Bowls, R/R Replace and Relocate, Coastered, Ear Shave, Front/Rear Tire Change, Replaced Final Gear Seals, Splines Lubed, Relay Coil Mod, Replaced Fork Seals, Rebuilt Starter
1stVulcan is offline
post #3 of 7 (permalink) Old 10-27-2012, 10:20 AM Thread Starter
When you put it in gear before it sounded like a fork in a blender.....
Took it out for a spin afterwards and it really seems to run well, I just need to adjust the handle bars up a little, the po had them set back further than I like them.
post #4 of 7 (permalink) Old 10-27-2012, 07:36 PM
....* splines were shot and he's worried about bar angle....lol*....frickin love it !
Thats like me..."yaaa, I know my cam chain's so loose its gonna come flying outta the valve cover, but we got a ride to do...I'll just add some 20-50"...awesome brother...
post #5 of 7 (permalink) Old 10-29-2012, 12:26 PM
RamblinRingo
RamblinRingo's Avatar
Yikes! I haven't gotten around to checking either of my splines yet, this really puts a fire under my @$$
94 Vulcan 750
RamblinRingo is offline
post #6 of 7 (permalink) Old 10-29-2012, 12:50 PM
You and me both !!
Old Bike: 2006 VN750 - Sold
eusjma is offline
post #7 of 7 (permalink) Old 10-29-2012, 09:34 PM Thread Starter
Well, it took me about an hour to pull the old final drive, replace the shaft coupling, lube everything and put it back together with the new final drive. Just get a 27mm socket for the rear axel nut, and the rest is pretty easy, check out fergy's spline lube procedure.
