fix for grinding clutch and shifter - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 7 (permalink) Old 10-20-2012, 12:10 PM Thread Starter
wildman
i used lucas heavy duty oil stabilizer,i just used the regular kind not the kind specifacly for motorcycles,it says on bottle its good for wet clutch systems on bikes... my bike shifts better than it ever has and u can get on it bone cold and theres no clutch noise and that jerky and jumpin clutch when cold is gone!!!!!!this stuff works great!! i would recomend it to anyone!!!
hambone71 is offline
post #2 of 7 (permalink) Old 10-20-2012, 08:41 PM
Wow thats cool how much of the bottle did you add?
jj23 is offline
post #3 of 7 (permalink) Old 10-21-2012, 11:13 AM
Did a bit of googling and found this... Only the Synthetic version does Lucus say it's designed for MC's. And use use at 10% on a wet clutch motor. But I could be wrong.
It can also be used to protect new and used Heavy Duty and High Performance transmissions, gear boxes and engines. Controls heat and wear in motorcycles, air-cooled engines and all drive train components
Source
Works to control heat and wear in high performance motorcycles as well, especially Harley Davidson (use 25%-30%). For 4-Stroke motorcycles with wet clutches, use 10%, otherwise use 20%.
source
MCCT Mod
Pickup Mod
12 Volt Receptacle Mod
Memphis Shades Santa Cruz
Homemade Luggage Rack
NGK Iridium IX Spark Plugs
Harley Sportster Exhausts
Rotating/Flashing Tail Lights
170/80 Michelin Commander II
Saddlemen Highwayman Slant Jumbo Saddlebags
Bought 09/10 12.2k miles - 04/12 33.4k miles
CW-4 is offline
post #4 of 7 (permalink) Old 01-14-2013, 10:58 AM
Underider's Avatar
Just tried Lucas oil stabilizer (Hi-Performance Synthetic Oil Stabilizer). Drained out about a pint of oil and added half a bottle. As stated above, it says to use 10%. No beneficial effect this AM - clutch was grinding coffee when bike was cold.
Underider is offline
post #5 of 7 (permalink) Old 01-14-2013, 03:22 PM
post #6 of 7 (permalink) Old 01-16-2013, 06:46 PM
Steve
350ernie2's Avatar
On my last change of Oil, I used Castrol Magnatech and it made the clutch grinding almost disappear. It now only occurs on the first take away, not the first 5 minutes.
Steve
VN750
KH500
Ducati 350sss
350ernie2 is offline
post #7 of 7 (permalink) Old 03-21-2013, 09:25 PM
bow_dude's Avatar
Send a message via Yahoo to bow_dude
drilled the clutch hub like wolfie showed in his link and roach did when he rebuilt his 700 and doesnt have coffee grinder noise at all even with regular oils
little red bewitch
96 750 vulcanlittle red bewitch
12561 miles
r/r relocated
leathersaddle bags(take on/ off)
memphis slim windshield (depends on mood)
p/u coils set at .020
agm battery , flame embossed seat cover
drilled clutch hub(3-20-12)
stainless steel coasters (3-28-12)
toc mccts installed(4/3/13)also changed to led bulbs in tail lamp
k&n air filters (4/20/13)
iridium plugs(4/20/13) along with ngk plug caps
V&H pipes, crash bars , luggage rack 4/5/2014
bow_dude is offline
