Anyone have a spare clutch basket - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 13 (permalink) Old 07-30-2012, 03:44 PM Thread Starter
Looking for a clutch basket if anyone has one lying around.
I didn't have a grabbit tool to remove the clutch basket in the "twin" and got impatient and tried to use the studs to hold on to and snapped one. (Pic is from file footage, not mine)
If not there's a few on ebay. Thanks
post #2 of 13 (permalink) Old 07-30-2012, 06:32 PM
Patriot Guard Rider
The DEUCE's Avatar
Since that pic is from eBay with a price of $29.95 + $11.35 Shipping. How does $30 shipped sound?
VN750 #9300 & VROC #33453
The DEUCE is offline
post #3 of 13 (permalink) Old 07-30-2012, 09:54 PM Thread Starter
Sounds fair, PM sent
post #4 of 13 (permalink) Old 07-31-2012, 02:54 AM
Are you going to drill the basket to prevent clutch chatter? I mean since you have it out and all..
4/12/12 1st bike ever! 95 VN 750 13k
New plug wires
Iridiums
Coil relay mod
MCCT mod
EPA stuff removed
Rear signals shaved
Shinko 170-110 oversized tourmaster tires
Splines lubed
Front signals relocated.
skyboxer is offline
post #5 of 13 (permalink) Old 07-31-2012, 04:13 AM Thread Starter
I'll probably do it for good measure.
post #6 of 13 (permalink) Old 07-31-2012, 05:11 AM
Any advice for removing it without the tool, seeing as hindsight 20/20? Other than breaking it of course. :P
I'll probably take mine off to do the coffee grinder prevention mod as well. I'd probably have done the same thing thus my asking.
post #7 of 13 (permalink) Old 07-31-2012, 09:51 AM
My question would be how much is the "special tool"?
I've seen quite a few broken clutch baskets ALL caused by not using the right tool.
You can make your own tool from a couple of used metal clutch plates...if you have some laying around.......
post #8 of 13 (permalink) Old 07-31-2012, 04:56 PM
How about an oil filter strap? Of course for a big oil filter.
post #9 of 13 (permalink) Old 07-31-2012, 08:46 PM
I do have a nice heavy duty rubber strap wrench I used to hold the rotor whilst torquing down the rotor and balancer bolt. It held to over 60ft-lb with no slippage.
I wonder if that will do?
post #10 of 13 (permalink) Old 07-31-2012, 08:52 PM
Clutch hub bolt torque is around 83 ft/lbs I believe........
