bevel drive gearcase bolt torque - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 7 (permalink) Old 07-22-2012, 06:59 PM Thread Starter
Does anyone know the proper torque for the front bevel drive gearcase bolts? I tried search, and even my PDF copy of the VN750 manual, and cannot find it anywhere. Because these bolts are so long and flexible, I would like to know the proper torque so I don't break one or strip threads. Thanks.
suitcasejefferson is offline
post #2 of 7 (permalink) Old 07-22-2012, 07:10 PM
I hope that is what you were looking for
post #3 of 7 (permalink) Old 07-22-2012, 07:13 PM
Slim's numbers are the ones that I remember using as well. I had no issues myself.
post #4 of 7 (permalink) Old 07-22-2012, 08:05 PM
That is in lbs brother. That is almost nothing. Use a 1/4 in rachet if you don't have a in lb meter.
post #5 of 7 (permalink) Old 07-23-2012, 02:40 PM Thread Starter
I guess I will just have to do it by feel. I don't have a torque wrench that small, and I trust my own judgement more than the $20 one at Harbor Freight. I guess it should be fine if just snugged up little by little in the proper sequence.
post #6 of 7 (permalink) Old 07-23-2012, 04:53 PM
I rarely ever use a torque wrench unless it's absolutely critical that one be used.
I have both a 1/4 and 3/8 torque wrench form Harbor Freight, and so far they have worked great. I send them in every year and get them re-calibrated.
The smaller bolts can be tightened up with a 1/4 drive ratchet and socket. I use an extension so I can get a better feel on how tight they are.
Like you said you can do it by feel. Just make sure you don't over tighten them as they might strip on ya.
TSmith68 is offline
post #7 of 7 (permalink) Old 07-23-2012, 06:28 PM
Chucklehead
dragon159's Avatar
Aka the "light" German torque spec .....
Gutensnugg
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
