final drive rpm correct - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 5 (permalink) Old 06-29-2012, 08:06 AM Thread Starter
Question final drive rpm correct
im a fairly new cyclist and I bought a 01 vn750,love it but heres my question.
@ 65 mph the rpms are like 4ooo on the tach.I think im only getting about 30-32 mpg. Any feedback thanks
hulsizer70 is offline
post #2 of 5 (permalink) Old 06-29-2012, 08:18 AM
JM2001's Avatar
If you are running stock size tires you will read about 5 mph fast, 60 mph at 4000 rpms is normal. You should be getting around 42-54 mpg depending how you ride. I average about 48 mpg
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 5 (permalink) Old 06-29-2012, 01:31 PM
30-32 mpg is low. I get 42 to 60, if I stay from WOT and keep her at 45-50 mph riding the back roads. You running a stock setup? Cleaned the air filters? Checked the plugs? Adjusted the mixture screws? Air pressure of tires? Used any Seafoam lately? All the normal stuff to think of.
MCCT Mod
Pickup Mod
12 Volt Receptacle Mod
Memphis Shades Santa Cruz
Homemade Luggage Rack
NGK Iridium IX Spark Plugs
Harley Sportster Exhausts
Rotating/Flashing Tail Lights
170/80 Michelin Commander II
Saddlemen Highwayman Slant Jumbo Saddlebags
Bought 09/10 12.2k miles - 04/12 33.4k miles
CW-4 is offline
post #4 of 5 (permalink) Old 06-29-2012, 03:39 PM
I average about 48 also, but I've gotten as low as 36 when I really tach it out. Try a few ounces of Seafoam treatment in the gas and see if your performance improves, it might take a few tanks..... and it wouldn't hurt to check your plugs to see how they're burning.
Oh and WELCOME TO THE GROUP!!!
post #5 of 5 (permalink) Old 06-29-2012, 04:11 PM
The Tac is not off, its the speedometer. The tac reads in hertz wich when the tac reads 4000, it is getting 400 Hz
