O-rings! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 15 (permalink) Old 05-31-2012, 01:00 AM Thread Starter
Skankin' Vulcan
combatchuck's Avatar
O-rings!
So I'm gearing up to do some spline lubing for the first time on the VN750 I bought a month ago and I want to replace the o-ring, but I don't know which to get. Here are the ones listed in the manual. I've never done this before so I don't know which is which (even from the diagram) or which I'll have to replace when I have this all apart.
92055 92055-1044 RING-O,ID=18.64
92055A 92055-1280 RING-O,61.6MM
92055B 92055-1281 RING-O,35.8MM
92055C 92055-1332 RING-O,19.8X1.9
Combatchuck
Looking for:
Swingarm caps
Highway pegs or engine guard
PM if you got these for sale
1986 Vulcan 750
NGK Plug Wires and Iridium Plugs
AGM Battery
Shinko 230 Tour Masters @24,400 miles
Right side rebuilt after PO laydown
combatchuck is offline
post #2 of 15 (permalink) Old 05-31-2012, 03:46 AM
Ndr
This one: 92055 92055-1044 RING-O,ID=18.64
Ndr is offline
post #3 of 15 (permalink) Old 05-31-2012, 06:55 AM Thread Starter
Skankin' Vulcan
Thanks!
Combatchuck
Looking for:
Swingarm caps
1986 Vulcan 750
AGM Battery
post #4 of 15 (permalink) Old 07-02-2012, 08:50 AM
knees in the breeze!!!
Tofer76's Avatar
if you look up the spline lube threads you will find numbers that you can go to lowes and get a pack of like ten o rings for cheap ..i did but i dont have the numbers in front of me
http://map.vulcan750.net/
VROC# 33976
1994 VN750
MODS SO FAR:
honda shadow 750 sissybar
ear shaved, K&N pods
142/42 jets, Cobra pipes
oversized tires, vn800 seat
vn750 rad cover, Tank bib
custom mirrors, gel battery
Tofer76 is offline
post #5 of 15 (permalink) Old 07-03-2012, 02:47 PM
Fergy`s spline lube thread:
https://www.vn750.com/forum/showthread.php?t=17274
The old O-ring may not be damaged or need replacing.
Having one on hand is just a time saver if you do.
I just read through fergy`s spline lube thread again and did not find any general industry spec dimension O-ring numbers for the pinion spline.
Only Ma Kaw`s part number, the same as quoted by Ndr:
However the ID=18.64 mm (about 3/4") given above, and good judgement about thickness of the cross section of the rubber ring itself, may be enough to find o-rings at a well stocked hardware store.
See fergy`s last picture in part/post 1, and the second picture in part/post 2 to get an idea of the thickness/cross section of the O-ring needed for the pinion spline.
If anyone has an O-ring in their possesion that fits, perhaps you could measure its ID, OD and cross section with a pair of calipers and post the measurements in this thread as well as fergy`s thread. Thanks in advance.
post #6 of 15 (permalink) Old 07-03-2012, 07:04 PM Thread Starter
Skankin' Vulcan
To be on the safe side I just went ahead and ordered it by the part number. I'd rather not guess and ruin the back of my bike!
Combatchuck
Looking for:
Swingarm caps
1986 Vulcan 750
AGM Battery
post #7 of 15 (permalink) Old 07-03-2012, 09:00 PM
I just happened to get a couple from bike bandit today in preparation for my tire change/splines lube tomorrow. I only have a non metric dial caliper.
ID .770
OD .990
Thickness .142
Now since its rubber there is some error because it's pliable but if you can find one close that pliability should allow it to work.
4/12/12 1st bike ever! 95 VN 750 13k
New plug wires
Iridiums
Coil relay mod
MCCT mod
EPA stuff removed
Rear signals shaved
Shinko 170-110 oversized tourmaster tires
Splines lubed
Front signals relocated.
skyboxer is offline
post #8 of 15 (permalink) Old 07-03-2012, 09:11 PM
Some metric conversions for you
OD: 2.5146cm
Thickness: 3.6068mm
post #9 of 15 (permalink) Old 07-03-2012, 09:26 PM
Hey skyboxer thanks for the measurements.
When you pull the final drive off tomorrow, would you please check the diameter of the pinion shaft where the O-ring sits.
Just curious how tight that 0.770" ID O-ring fits on there.
post #10 of 15 (permalink) Old 07-04-2012, 01:09 AM
That's an excellent idea. I should get more accurate readings on the steel.
New plug wires
Iridiums
Coil relay mod
MCCT mod
EPA stuff removed
Rear signals shaved
Splines lubed
skyboxer is offline
Tags
lube , o ring , o-ring , spline
