please help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 6 (permalink) Old 05-30-2012, 12:10 PM Thread Starter
wildman
please help
I am having to replace my shifter shaft or rod not sure what u call it..its the one that connects to the shifter itself ,someone had welded shifter to other one and damaged seal causing an oil leak....now my mechanic has it and was going to replace seal,shaft and shifter. now he says he may have to pull motor completely and split case.thinkin bout cuttin shaft behind seal and welding piece on. IS THERE ANY WAY TO CHANGE THIS WITHOUT SPLITTING CASE??????
hambone71 is offline
post #2 of 6 (permalink) Old 05-30-2012, 01:08 PM
Some one here did it, but it is very difficult. You might take a file or demmell tool and clean up the end of the shaft.
Welding another end on it is not a bad idea.
post #3 of 6 (permalink) Old 05-30-2012, 02:11 PM
Nettrain's Avatar
Send a message via Skype™ to Nettrain
There's a great description on here of someone replacing a paul spring or clamp without cracking the case, but I didn't see any on replacing the shifter(tie-rod) shaft. Mine's in pieces right now waiting for gaskets after getting the $35.00 shaft.
'06 VN750
All Stock-10,700
Nettrain is offline
post #4 of 6 (permalink) Old 05-30-2012, 02:34 PM
It is on here. I found it once. Can't seem to find it again.
post #5 of 6 (permalink) Old 06-08-2012, 11:10 PM
Here is a link to bigpakapump`s description of changing the tie rod w/o splitting the cases.
https://www.vn750.com/forum/showthread.php?t=19276
post #6 of 6 (permalink) Old 06-09-2012, 11:32 AM
He's done it OlHoss it was the shaft to the gear foot change, he welded it on it's in another topic
Swagman is offline
