Honda Moly 60 price - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 7 (permalink) Old 05-30-2012, 12:09 PM Thread Starter
Honda Moly 60 price
I'm assembling everything I need to rebuild my final drive. Ordered the Honda Moly 60 from Dexters on ebay for $11.47 including shipping. No mention was made in the ad of the product size. It arrived in record time but I was quite shocked to see the tiny size of the tube (3 oz); I'm used to seeing the 16 oz size used in grease guns and assumed (we know what that means) that's what I was getting. Is that the only size for the lube and was that a fair price for a tiny 3 oz tube?
Thanks for anyone's $0.02.
To Do List:
-T7 stator mod
-R/R relo
-MF Battery
-voltmeter
-ignition switch
-ACCT's to MCCT's
-LED brake & turns
-spline lube
Did I miss anything?
Kayakrazy is offline
post #2 of 7 (permalink) Old 05-30-2012, 01:48 PM
That is about right. You don't use a lot of it so the tube will last some time.
post #3 of 7 (permalink) Old 05-30-2012, 02:11 PM
Captive New Yorker....
peterherrm's Avatar
I paid 10.49 on ebay a few months ago for 3oz.
Pete Herrmann
Bought 4/2011 28k Miles,
New Rick's Motorsports R/R
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
peterherrm is offline
post #4 of 7 (permalink) Old 05-30-2012, 03:28 PM
Crap, I WAS in 5th gear.
Moly Lube
You can just use any moly-containing bearing lube. I use Motorcraft spec, because I have it laying around from doing my stupid Expedition brakes, where the bearing hub is part of the rotor, &%$#*.
Kelly2001 is offline
post #5 of 7 (permalink) Old 05-30-2012, 09:09 PM
JM2001's Avatar
$8.95 for 3 oz tube at my Kawasaki/Honda/Yamaha dealer.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #6 of 7 (permalink) Old 05-30-2012, 10:29 PM
It was about $16 CAN for the 100 gram tube at the local Honda Stealership when I first looked 3 years ago.
Last summer they were asking about $24 IIRC.
Most moly grease in the 14 oz tubes will only be a moly content of about 3% in my experience.
I have a 90 gram tube of "Moly based" CV Joint lube from NAPA that was ~$3.50. It may be only 3% moly too, as it does not specify.
Note on it says it also contains lead compounds.
I am going to use it for the spline lube in the next week or two.
I will need a new rear tire before 10K miles, so will see what the CVJoint lube looks like then.
post #7 of 7 (permalink) Old 06-01-2012, 03:17 AM Thread Starter
Thank you
Thanks again everyone for your responses!
To Do List:
-T7 stator mod
-R/R relo
-MF Battery
-voltmeter
-ignition switch
-ACCT's to MCCT's
-LED brake & turns
-spline lube
