Pops off when trying to start - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #2 of 12 (permalink) Old 05-26-2012, 12:15 AM Thread Starter
Alatri's Avatar
CLICK ON MY FIRST POST AND IT GOES TO THE PICTURE
Alatri is offline
post #3 of 12 (permalink) Old 05-26-2012, 12:50 AM
sparkingdogg's Avatar
that is the middle drive cover cap. mine fell off years ago, the rubber seal dries out. a new one wasn't very much, maybe $15 if i remember right. don't buy the "special tool", when you get the seal, take it to home depot and buy a rigid electrical conduit coupling, i believe it was 1 1/2", it fits perfectly and costs $3 or so. take the seal with you and you will see how it should fit. tap it gently in using the rigid coupling and a plastic dead blow hammer or something similair. make sure it goes in STRAIGHT and not CROOKED. if it comes out that easy i imagine your seal is dry, the new cap has a seal built on. there should not be much pressure at all on the oil in your crank case, but ANY pressure will make it fall out if the seal is dry. a new cap should fix your problem.
2003 VN1500 Nomad FI Bagger
2004 KLX400SR Dual Sport light adv bike
1969 CB750 K0 sand cast #1767
couple of nice GL650 Silver Wing Interstates, one with hack
2 and 4 stroke dirt bikes
other vintage stuff back in the corner
sparkingdogg is offline
post #4 of 12 (permalink) Old 05-26-2012, 10:15 PM Thread Starter
Alatri's Avatar
Not seeing any sort of o-ring or seal on the inserted portion of the cap???
nor any sort of groove that would secure any o-ring or seal in one place.
Alatri is offline
post #5 of 12 (permalink) Old 05-26-2012, 10:45 PM Thread Starter
Alatri's Avatar
Or are you talking about past the nut that is located under the cap that pops off, it has little dashed grooves facing me, played around with it for a minute with an o-ring inser/remover tool but am not sure if the nut has to come out first so I left it alone till I got someone to answer,
You would remember where you found the part #?
Can't find it in the Kawasaki part diagrams, well, can't find that little area of the bike anywhere in the diagrams.
Alatri is offline
post #6 of 12 (permalink) Old 05-26-2012, 11:14 PM
are we talking about part #11012?
post #7 of 12 (permalink) Old 05-27-2012, 12:11 AM Thread Starter
Alatri's Avatar
Yeap! thats the cap that pops off after a few seconds of attempting to crank the bike over,
i am not seeing any signs of an old o-ring to replace???
Alatri is offline
post #8 of 12 (permalink) Old 05-27-2012, 09:21 AM
the o ring is probably gone. #671
post #9 of 12 (permalink) Old 05-27-2012, 11:06 AM Thread Starter
Alatri's Avatar
Would that o-ring be placed on the inserted part of the cap?
when looking at the cap, i don't notice any sort of groove for an o-ring to sit in?
not understanding where the o-ring would go to provide a seal to prevent the oil from dripping and the cap to stay on,
Alatri is offline
post #10 of 12 (permalink) Old 05-27-2012, 01:02 PM
the cap has an external flange, the o-ring rests against this flange.
