Small Transmission oil leak, Need a little guidance - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 4 (permalink) Old 05-04-2012, 08:04 PM Thread Starter
Striker1's Avatar
I have had a little, and I mean a very little bit of oil coming from the chrome cap on the gearbox. It doesn't even drip, just a little bit of oil accumulated around the bottom of the chrome cap. I know there is a seal in there, I was just wondering how hard this is going to be to change as looking at the exploded view of it, it looks fairly difficult, but so did the exploded view of the splines and that was a piece of cake. I have searched and found a little info on it. Thank yall for any knowledge you may be able to share on this particular procedure.
1986 Vulcan 750
30,000 miles and counting
Castrol GTX 10w-40
WIX- Gold oil filter Pt.#1356 @ Napa Auto supply $8.00
Seafoam-2 oz. to every other tank of gas @ Napa-$10
Yuasa M/F battery- YTX14AHL-BS
Lubed Splines- Moly EP Grease, 1lb. tub $3.49-Autozone Pt.#561753
Sprayed U-joint with Liquid Wrench White Lithium Grease- $3.99 Autozone Pt.# 828796
Castrol Hypoy C 80w90 Gear Oil $5.99- Autozone Pt.#991558
NGK Iridium IX Spark Plugs, $8.99(x4)=$35.96 Autozone Pt.#088394.
Degoated
Striker1 is offline
post #2 of 4 (permalink) Old 05-05-2012, 03:38 PM
If yout talking about the bevel gear & the chrome cap on that, If I'm not mistaken you just need to remove it & replace it. You shouldn't need to even remove it.
post #3 of 4 (permalink) Old 05-05-2012, 05:01 PM
Roach's Avatar
After I did my engine rebuild mine popped out from the pressure created in the case. I just put some RTV silicone around it and plopped it back in. Seems to hold up just fine.
You can probably pop it off with a screwdriver.
Street
1985 VN750 Acquired Feb, 2011 - 13,676km
Mods - Ear Shave, Pickup Coil Gap, Drilled Clutch Basket, Shift Tie Rod, Mosfet R/R, MF Battery, De-Goated (H-Pipe), MCCT, Heated Grips, Plexistar 2 Windshield
Dirt
2004 KTM SX 125 - 1979 Can-Am Qualifier 250 - 1971 Kawasaki F6
Video Tutorials - Engine Rebuild - Fork Seal Replacement - Grease Swing Arm Bearings - Carb Rebuild - Spline Lube - Refilling Rear Shocks - Grease Steering Bearings
Roach is offline
post #4 of 4 (permalink) Old 05-06-2012, 12:40 AM Thread Starter
Striker1's Avatar
Thank yall guys. I will be taking care of it tomorrow.
1986 Vulcan 750
Castrol GTX 10w-40
Degoated
Striker1 is offline
