Floppy Shifter - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 17 (permalink) Old 04-02-2012, 03:33 PM Thread Starter
Nettrain's Avatar
Send a message via Skype™ to Nettrain
Cool Floppy Shifter
Hi, new to this forum but not new to Kawasaki, have a KZ440, too. Anyway, I was thrilled to get a great deal on my 06 VN750, drove it for 3 days when the weather finally allowed and then drove it home and down my long bumpy-assed driveway, went to get on it an hour later and the shifter just flops! It is stuck in first gear and there is about 80 degrees of play on the shifter up and down and at least 1/4" in and out. I had to drive it in first all 8 miles to town, very sad. I've always liked my Kawasaki's but this is pretty scary if it's going to happen a lot. I've seen possible Pawl Spring on here but wonder if this is a chronic problem with bumpy roads and what anyone thinks about my issue? Thanks for any replies...
Nettrain is offline
post #2 of 17 (permalink) Old 04-02-2012, 04:51 PM
JM2001's Avatar
Could be the pawl spring. Bumpy roads can dislodge it. Check this thread
https://www.vn750.com/forum/showthrea...ht=pawl+spring
Especially post # 10
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 17 (permalink) Old 04-02-2012, 05:26 PM Thread Starter
Nettrain's Avatar
Just read it, thanks, now I gotta get this info to my mechanic...
Nettrain is offline
post #4 of 17 (permalink) Old 04-02-2012, 05:27 PM
Member? ... check.
ZCraggRatt's Avatar
This does not sound like a pawl spring problem. If it is just a pawl spring issue, the shift lever will not have 80 degrees rotation. This sounds more like a shift lever tie rod snapped or popped off. I hope not. Maybe the more experienced folks will chime in soon.
~~C8>
ZCraggRatt is offline
post #5 of 17 (permalink) Old 04-02-2012, 06:13 PM Thread Starter
Nettrain's Avatar
Craaap...
Now I'm worried again, the thing definitely travels 5-6 inches at the end of the shifter. Still connected, tho, would it still travel that smoothly if it was broke?
Nettrain is offline
post #6 of 17 (permalink) Old 04-02-2012, 06:22 PM
Member? ... check.
ZCraggRatt's Avatar
When my pawl spring got stuck, the gear shifter had normal range of motion and spring return, I just couldn't change gears. I was unfortunately stuck in neutral when it happened to me. I was really pissed. But the bike didn't care. First gear would have been great! The pawl spring acts more like a retaining spring than a tension or return spring.
The pawl spring is still the first thing to check (easy). As a matter of fact, it looks like if the pawl pulls away or falls off the change shaft, it might have the symptoms you describe.
But if the pawl spring area is ok, the next culprits are the gear change lever and the tie rod. Upload the service manual and look at the assemblies. The '06 isn't in there, but you can see the same in the '04.
Kanuck69 has a link to a service manual download in his signiture. It is a large file.
~~C8>
post #7 of 17 (permalink) Old 04-03-2012, 03:24 PM
It sounds like 2 different problems. It is not that uncommon for the shifter shaft to slide in and out quite a bit, especially if the bike has been dropped on the shifter. Something breaks inside the engine that allows the shaft to move in and out like that. Out is the proper position for it, and many people just install a spacer between the shifter and the case to hold it in that position. Pull the shifter all the way out, and see if it still has several inches of play in it. If so, you likely have a far more serious problem. There is a linkage rod inside the case that could have broken or come loose. Fixing it requires a complete engine teardown and splitting the cases. I hope that isn't it.
Your bike may have been the victim of a first time rider, or a bike abuser. Some riders will just stomp on the shifter, and that will usually cause serious internal damage. The shifting mechanism is a pretty delicate thing on most bikes.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #8 of 17 (permalink) Old 04-04-2012, 12:17 PM Thread Starter
Nettrain's Avatar
Thanks Jerry, I hope that isn't it, too, or my great deal suddenly looks pretty crappy. It only has 10K on it but I did let a big friend of mine ride it and he may not be as gentle on it as me. I may have to reconsider letting anybody else ride my bike...
Nettrain is offline
post #9 of 17 (permalink) Old 04-04-2012, 02:08 PM
There is a way to replace the shifter rod with out splitting the case. One member here did it, but I can't find the thread where he described the procedure. I will keep looking.
Here it is.
https://www.vn750.com/forum/showthrea...ht=shifter+rod
post #10 of 17 (permalink) Old 04-04-2012, 05:35 PM Thread Starter
Nettrain's Avatar
Freaking awesome link, Niterider, Thanks!
'06 VN750
All Stock-10,700
Nettrain is offline
