Front bevel gear - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 6 (permalink) Old 04-01-2012, 01:43 AM Thread Starter
Let's Ride!!
DaveT319's Avatar
Front bevel gear
I've discovered a leak at the front bevel gear case. Is it possible to remove it without draining all the oil first? It's fresh oil so I'd rather not mess with draining it if I can. Could I just tip the bike to the right side so all the oil collects away from it?
DaveT319 is offline
post #2 of 6 (permalink) Old 04-01-2012, 01:49 AM
nope.. you have to drain the oil.. get 2 clean coffee cans and a couple of coffee filters... drain the oil into one coffee can, then filter the oil into the second can with the coffee filters.
post #3 of 6 (permalink) Old 04-01-2012, 02:06 AM Thread Starter
Let's Ride!!
DaveT319's Avatar
Darn. Oh well. Is a single coffee can big enough to hold all the oil?
DaveT319 is offline
post #4 of 6 (permalink) Old 04-01-2012, 02:12 AM
as long as you didn't over fill it
post #5 of 6 (permalink) Old 04-01-2012, 02:25 AM Thread Starter
Let's Ride!!
DaveT319's Avatar
Don't think I did, plus some leaked out!
DaveT319 is offline
post #6 of 6 (permalink) Old 04-01-2012, 08:48 AM
you should be fine... you might want one more can... just in case.
