Too much lube for splines?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 8 (permalink) Old 03-26-2012, 03:30 PM Thread Starter
Kufbass
Kufbass's Avatar
Ever since I had my new tires put on by the motorcycle shop I have been getting black greese on my rims. I was wondering if they put too much lube on the splines, or did they not tighten something to cause it to leak? I was wondering if it is going like this, is it going to eventually run out of greese and then rust. Thanks for the answers!!
2002 Vulcan 750
V&H Pipes
K&N Air Filter
NGK Iridium Spark Plugs
Green Led Night Lights
Shinko 230 Tour Master Tires
Kufbass is offline
post #2 of 8 (permalink) Old 03-26-2012, 03:52 PM
Sounds like it's leaking from the final drive. Take a close look at where the grease is coming from. Where the splines are located, it's pretty much sealed. If they used an improper grease or too much grease on your final drive, it could come from there.
post #3 of 8 (permalink) Old 03-26-2012, 05:40 PM
First make sure it is not gear oil, which looks black when dirty. If it is grease, it has to be coming from the splines on the rear wheel, as the driveshaft is sealed. Moly paste should not come off like that. Before I found out about moly paste, I used moly wheel bearing grease, and had the same problem.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #4 of 8 (permalink) Old 03-26-2012, 07:42 PM Thread Starter
Kufbass
Kufbass's Avatar
It is comming from the little space between the wheel and the shaft. It seems I looked that is all I can tell without taking off the wheel. It does smell like grease. I looked around the final drive nuts,and there is no leaking.
2002 Vulcan 750
V&H Pipes
K&N Air Filter
Kufbass is offline
post #5 of 8 (permalink) Old 03-26-2012, 09:37 PM
Yup. Excess grease from the final drive. Clean it up & ride a bit more keeping an eye on it. If you see more come out contact the shop that did the work & ask them what type of lube they used on the final drive & that you have excess grease being flung from it. This should not leak like that & is not normal.
Make them do the work if they suggest removing the wheel to clean up the grease.
post #6 of 8 (permalink) Old 03-26-2012, 11:49 PM
Striker1's Avatar
I just did my splines 2 days ago, and I packed good with moly grease. I didn't think you could over lube them to a certain extent of course, but since you can over lube them I guess I did. However I do not have anything coming out of anywhere. Except those 2 little drops of oil that I find when I have my bike on the side stand after driving it. I can vouch for Moly Grease.
1986 Vulcan 750
30,000 miles and counting
Castrol GTX 10w-40
WIX- Gold oil filter Pt.#1356 @ Napa Auto supply $8.00
Seafoam-2 oz. to every other tank of gas @ Napa-$10
Yuasa M/F battery- YTX14AHL-BS
Lubed Splines- Moly EP Grease, 1lb. tub $3.49-Autozone Pt.#561753
Sprayed U-joint with Liquid Wrench White Lithium Grease- $3.99 Autozone Pt.# 828796
Castrol Hypoy C 80w90 Gear Oil $5.99- Autozone Pt.#991558
NGK Iridium IX Spark Plugs, $8.99(x4)=$35.96 Autozone Pt.#088394.
Degoated
Striker1 is offline
post #7 of 8 (permalink) Old 03-27-2012, 08:34 AM
There's lubing your splines (sealed) & there's lubing the gears on your final drive (not sealed but tight fit) where it meshes with the rear wheel. I'm pretty sure he's having an issue with excessive grease leaking from the later.
post #8 of 8 (permalink) Old 03-27-2012, 10:07 AM
Striker1's Avatar
Gottcha, I mollied that up too.
1986 Vulcan 750
Castrol GTX 10w-40
Degoated
Striker1 is offline
