clutch life - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 14 (permalink) Old 03-21-2012, 08:17 PM Thread Starter
gun slinger
centurynick's Avatar
clutch life
how long these last ? i have a tad over 14,000 on this one i just switch to an over sized rear conti tire . i do a lot of 2 up rideng ( previous was a stock 404 tire) it seems to slip more so when it gets hot ( after 30 miles ) and only if i get on it ( above 5k rpms )
2010' voyager
2005 1600 nomad sold
1987 kawasaki vulcan 750 SOLD
1985 kawasaki vulcan 700 parts bike maybe
lots of hand guns
3 cagers doors kicked in
centurynick is offline
post #2 of 14 (permalink) Old 03-21-2012, 08:23 PM
1986vn750's Avatar
maybe You need to readjust you cable, due to the clutch wearing a little. Im not an expert on this, but our 86 has 18,800 miles and its clutch feels just like my 2001 at 13,000 miles.
1986 Vn750
18,800 miles, and counting
Bone Stock
New cam chain tentioners
all fluids changed
Spline Lube
windshield
Engine Guard
B-stone S11 RWL-stock sizes
*wanted*
New grips
2001 Vn750
13,100 miles, and counting
spline lube
Bridgestone S11 100/90
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
1986vn750 is offline
post #3 of 14 (permalink) Old 03-21-2012, 08:46 PM Thread Starter
gun slinger
I should shoot myself in the foot for bypassing the obvious!
2010' voyager
lots of hand guns
post #4 of 14 (permalink) Old 03-21-2012, 08:53 PM
I rebuilt mine with a Kevlar kit at 6000 miles because it was slipping at high rpms under load. Two up riding here too...Went to pass a truck at 70-80 mph and it wasn't getting all the power to the wheel. Could actually hear it slipping.
New clutch and heavier springs cured it. Some folks might just be more "gentle" than me on the bike, but a new bike with a slipping clutch with those miles seemed off to me.
So, to answer your question, there's no telling how long your clutch will last. Most bikes I've owned I put in aftermarket clutches in at some point. To be fair, no problems yet with my FJR.... But I think they knew going in that a 145 hp motor required a stronger clutch.
"normally" your clutch should last at least 30,000 miles. But as they say, YMMV......
post #5 of 14 (permalink) Old 03-21-2012, 09:45 PM Thread Starter
gun slinger
i just thought i would get some more out of it , then again i litterally ride the bike non stop it is now transportation to me the car and the truck just sit most the time
2010' voyager
lots of hand guns
post #6 of 14 (permalink) Old 03-22-2012, 08:42 AM
I've got 42,000 on my bike with the origional clutch still in it and it feels good. I'm suspecting I'll be up for one bu next season.
post #7 of 14 (permalink) Old 03-23-2012, 05:25 PM
There's a thread somewhere on these forums where I read that especially if a bike has sat for awhile, to expect a lil slippage, and that sometimes removing the glaze on the disks solves the problem. My bike sat for 5 years, and like Knife, getting some slippage at higher rpms under load. Mine only has 20k miles on it, and I cant afford new disks yet, so will try de-glazing first. Springs feel real stiff at the lever too, so I think theyre ok.
post #8 of 14 (permalink) Old 04-17-2012, 12:38 AM
My bike has about 40k on it.. Aside from needing an adjustment I don't feel any slipping at any speed.. But I guess I'll find out soon I want to change out my springs to cure the coffee grinder issue.. as I was shopping ebay I found a great deal on some new kawasaki friction plates tonight.. still need one more so make a set but haven't decided on the springs I want.
1995 VN750 (SOLD)
05-06 CBR600 R/R
ACCT>MCCT mod
engine guard w/HW pegs
Tires, 230's (170/110)
Smaller blinkers
Driving lights
Pickup coil mod
Speedo delete
mirrors w/reverse mount
Black grips
2000 Buell X1 Lightning
Carbon fiber fender F&R
Carbon fiber fly screen
Carbon fiber race intake
Works Shock
V&H Muffler
SS headers
Roncgizmo is offline
post #9 of 14 (permalink) Old 04-17-2012, 01:33 AM
Mostly depends how you ride it. I ride solo, and mostly on the highway, and got close to 70,000 out of it. Stop and go riding, carrying more weight, or having a bigger than stock tires (more rolling resistance and mass) will all shorten the life of a clutch, as well as how you use it. If you slip it a lot taking off, it will wear down faster. The stock clutch lasted longer for me than I thought it would, and since I replaced it with EBC discs, I doubt I will ever have to replace it again.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #10 of 14 (permalink) Old 04-17-2012, 10:16 AM
Crap, I WAS in 5th gear.
Coffee Grinder
There was a drawing provided by Momma Kaw that detailed drilling holes to solve the coffee grinder issue. If you pull theclutch be sure to do this.
Kelly2001 is offline
