Stallout issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 7 (permalink) Old 03-18-2012, 02:25 PM Thread Starter
Captive New Yorker....
peterherrm's Avatar
Stallout issue
I just installed a new stator and went to take the bike out for a test ride, an it will not allow me to fully release th clutch without it stalling out. It sometimes backfires. If I engage the clutch it runs perfect. I was having this issue intermittently before I took the bike apart. I was thinking maybe the stand switch might be faulty. Any ideas??
I can accelerate just fine with the clutch half depressed, but if I release all the way, the rpms get very low and it dies.
Pete Herrmann
Bought 4/2011 28k Miles,
New Rick's Motorsports R/R
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
peterherrm is offline
post #2 of 7 (permalink) Old 03-18-2012, 02:54 PM Thread Starter
peterherrm's Avatar
Just tried taking it out again, and after releasing the clutch slowly a few times, it went into first just fine and now is running and switching into all gears perfectly. The problem seems to be intermittent.
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
post #3 of 7 (permalink) Old 03-18-2012, 03:28 PM
how does the jb connections look?
post #4 of 7 (permalink) Old 03-18-2012, 08:49 PM Thread Starter
peterherrm's Avatar
Is jb junction box? If so, the connections all seem fine, nothing loose or burned up.
It then was stalling out completely and I pulled on the side stand switch and then it ran just fine. Maybe my side stand switch is bad??
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
post #5 of 7 (permalink) Old 03-19-2012, 08:58 AM
flitecontrol's Avatar
They tend to stick, so that could be it.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is online now
post #6 of 7 (permalink) Old 03-19-2012, 11:36 AM
Yes, probably the stand switch.
post #7 of 7 (permalink) Old 03-19-2012, 06:49 PM
i agree side stand switch since the junction box (JB) looks good
