grabbing clutch - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 30 (permalink) Old 12-03-2011, 11:48 PM Thread Starter
trekbiker's Avatar
grabbing clutch
Anyone have trouble with your clutch being grabby instead of smooth in the friction zone. Mine seems to be more and more that way lately making it hard to do smooth starts. it also makes it interesting when maneuvering at slow speeds. I am in Atlanta so the weather is not amazingly cold here - I pretty much ride in the night/evenings commuting to and from work so its in the mid 30's -
I am running GTX 20/50 which has been in the bike for about a year perhaps. Today I went out to work on some slow speed bike handling skills and it about drove me nuts. It feels like it wants to be in or out with no middle ground.
That can't be my bike - it aint movin'
trekbiker is offline
post #2 of 30 (permalink) Old 12-04-2011, 08:46 AM
Chuck A.'s Avatar
I'm here in Bama so about the same on the temps. My bike was doing the same thing until I went to Castrol 10/40. Never tried the 20/50. I would think that may be a little thick for temps this time of year. I tried the full synthetic oils and it made mine extremely rough on take off.
Chuck A. is offline
post #3 of 30 (permalink) Old 12-04-2011, 01:54 PM
20w50 is not really a good choice for temps under 80. I'd switch to a 10w40 and see if it helps... If not, you might need a new clutch, as it might be a warped or worn out plate(s).
Do make sure you clutch cable is adjusted properly of course....
post #4 of 30 (permalink) Old 12-04-2011, 05:00 PM
If only it had 6th gear..
DavesVulster's Avatar
Mine does it too in the cooler weather. X2 on the thickness of the oil and quite possibly the brand. Thinner oil is better in the cooler temps for bikes and cars. With mine I just let it warm up and work the clutch lever a few times. Not really sure if that makes a difference but it stops that ridiculous behavior after a few minutes of riding. I'm planning on trying Castrol in it next oil change. Good luck.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #5 of 30 (permalink) Old 12-04-2011, 08:02 PM
DavesVulster
x2 ... I use Synthetic 15-40 Delvac (Mobil 1) , start bike (No Choke), warm up 60 seconds, work the clutch lever 2-3 times.. never a clutch issue / no grabbing / all is normal.
Suggest 10-40 or 15-40 Oil... best solution to avoid clutch grabbing.
WilliamTech
post #6 of 30 (permalink) Old 12-04-2011, 11:28 PM Thread Starter
trekbiker's Avatar
Thanks
I will do an oil change this week and see if that doesn't correct the problem
I was thinking of using royal Purple max cycle 10/40
Also will check cable adjustment - are there guidelines or is it just till it feels right?
post #7 of 30 (permalink) Old 12-04-2011, 11:40 PM
Smile
Originally Posted by trekbiker View Post
Thanks
Basically, a nickel ($.05) thickness of free play at lever.
Search threads for clutch lever adjustment.
WilliamTech
post #8 of 30 (permalink) Old 12-05-2011, 12:07 AM
I just did an oil change with some "SuperTech" 10W-40 and this went away, even during the first couple of take-offs.
The oil isn't exactly anything special, it's just a basic non-energy conserving oil.
post #9 of 30 (permalink) Old 12-05-2011, 02:16 AM
Smile
thTanner
http://motorcycleinfo.calsci.com/Oils1.html
The above link is a lengthy long (partial) education of Oils.
MC oils info starts one-half way through the article. After much research and reading this article, my choice of Oil is Synthetic Delvac 15-40.
Spend the time on researching quality oil for MC's... your bike will benefit greatly.
Also, brand of oil filter choice is also crucial.
Good Luck
WilliamTech
post #10 of 30 (permalink) Old 12-05-2011, 12:32 PM
Hey...let's turn this into an oil thead...
I use Rotella T NON synthetic oil. Buy it in the big jug at Wal-Mart.
Works great....and I'm not alone with that opinion. You don't need special/expensive "motorcycle" oil.
