Spline Lube Video - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 12 (permalink) Old 09-27-2011, 02:20 PM Thread Starter
Roach's Avatar
Spline Lube Video
Hey all,
I made a spline lube video.
It's a little different than the standard procedure as the engine was out and I could remove the propeller shaft. It should still give a good idea of what is involved.
Street
1985 VN750 Acquired Feb, 2011 - 13,676km
Mods - Ear Shave, Pickup Coil Gap, Drilled Clutch Basket, Shift Tie Rod, Mosfet R/R, MF Battery, De-Goated (H-Pipe), MCCT, Heated Grips, Plexistar 2 Windshield
Dirt
2004 KTM SX 125 - 1979 Can-Am Qualifier 250 - 1971 Kawasaki F6
Video Tutorials - Engine Rebuild - Fork Seal Replacement - Grease Swing Arm Bearings - Carb Rebuild - Spline Lube - Refilling Rear Shocks - Grease Steering Bearings
Roach is offline
post #2 of 12 (permalink) Old 09-27-2011, 02:42 PM
If only it had 6th gear..
DavesVulster's Avatar
Dude... you rock! Your vid's are so helpful. Thanks for making them. It is appreciated by many for sure. Got to subscribe to your yt page also. Take care.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #3 of 12 (permalink) Old 09-27-2011, 05:47 PM
VoIPDoc is offline
post #4 of 12 (permalink) Old 09-27-2011, 06:18 PM
Ceal's Avatar
I keep favoriting your videos! Thanks!!
You know, I asked this guy at Autozone if they might have Moly60 grease... he pointed me to a can of spray on white lithium grease... u_u he said "it's the same thing!".
Ceal is offline
post #5 of 12 (permalink) Old 09-27-2011, 07:05 PM
Not surprised Ceal (sigh).
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
post #6 of 12 (permalink) Old 09-27-2011, 10:41 PM
Another great help for forum members Roach.
I recall someone mentioning that you can fill the final drive through the hole located at 2 O`clock on the circumference that is plugged with "set screw" type bolt with a 6 mm allen head. The 1 liter gear oil bottles come with a tapered nozzle, and you just keep adding oil until it starts to run over the threads in the oil level check hole that you were filling through.
post #7 of 12 (permalink) Old 09-28-2011, 10:49 AM
OldBikeNewRider's Avatar
Guys like you an Fergy are the Men!!! Thanks!
1986 VN 750
20,000 miles
Replaced Stock Turn signals
Starter Clutch
NGK plugs
MT66 Pirelli's
Seafoam
OldBikeNewRider is offline
post #8 of 12 (permalink) Old 11-19-2011, 04:01 PM
I've said it before, but your videos are better than the manual. Next time I lube my splines (in the next couple thousand miles), I intend to remove both the front bevel drive gearcase, the final drive gearcase, and the drive shaft, clean everything up really well with brake cleaner, and give everything a good coating of Guard Dog 570 73% moly paste. I've never had the front gear case off before, I've been pulling the boot back, dropping the swingarm as far as it will go, disengaging the U joint from the output shaft, and using a popsickle stick to put grease on the output shaft and in the U joint.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #9 of 12 (permalink) Old 11-19-2011, 05:46 PM
OldHipWesTex's Avatar
Send a message via Yahoo to OldHipWesTex
Yeppers "Mr. Roach" there has great videos on youtube, ive watched all of them that are posted. Dont really need the manual except for a second hand back now Give Mr. Roach the New Shiney Vulcan 750 Award!
Vulcan #1 1993 - 28K
Vulcan #2 1999 - 26k
It All Comes Down To 3 Things:
#1 Fuel
#2 Spark
#3 Mechanical
Any One Fails - Then It Dont Run
____________________________________
ANTICIPATED MODS:
Build Fiberglass Fenders F/R
Mold & Cast New Turn Signals Lights
OldHipWesTex is offline
post #10 of 12 (permalink) Old 11-19-2011, 06:03 PM
Many Thanks Roach!!
1986 VN 750
20,000 miles
Starter Clutch
NGK plugs
MT66 Pirelli's
Seafoam
