Coffee grinder gone!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 4 (permalink) Old 09-23-2011, 09:05 PM Thread Starter
When I first got my 2002, the clutch would make the "coffee grinder" noise when I first took off in the morning.
I tried many different types of engine oil including full synthetic to try and get rid of this problem and nothing seemed to work........until I tried my old stand by oil. Castrol GTX 20-50!!!
Don't know why I did not do it before cause that is all I have used in all of my flattrack bikes for years.
No more clutch noise and shifts butter smooth!!!
honest Al is offline
post #2 of 4 (permalink) Old 09-23-2011, 09:27 PM
If only it had 6th gear..
DavesVulster's Avatar
That's good man. I tried castrol in mine before and it didn't get rid of it . Unfortunately it seems that each bike is different, maybe because of what was used in the engine previously I don't know. I deal with mine but sometimes I forget and it is embarrassing at times lol. Maybe I'll try it again and run 20-50 since I've only run 10-40 in it. 20-50 is a little thicker so I thought if anything it would add to the problem but again, I'm open to finding myself corrected. Especially if it means a smoother clutch take care.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #3 of 4 (permalink) Old 09-27-2011, 10:01 AM
robardin's Avatar
I'd be surprised if 20-50 oil doesn't get you a heavy, sluggish feeling clutch and harder starts in cool weather up where you are in Boston! I tried 20w50 early one July in NYC and went right back to 10w40 by mid September. Heck, I usually go to the Rotella T Synth 5w40 in October/November and 10w40 in April.
"Until you have the courage to lose sight of the shore, you will not know the terror of being forever lost at sea." (Despair.com)
robardin is offline
post #4 of 4 (permalink) Old 09-27-2011, 11:26 AM
JM2001's Avatar
I have the same good results with 20-50. I had to pull the synthetic after one day, bike was noisier, shifted harder, and ran hotter. I like Valvoline 20-50 Motorcycle Oil.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
