Ring & Pinion gear backlash,freeplay - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 12 (permalink) Old 08-01-2011, 03:33 PM Thread Starter
Engine off. I put bike in gear it will roll 2 1/2" before the ring and pinion gears( final drive) mesh together again . I can't believe this is normal. Does anybody have this situation. Splines are all fine I lubed at 5700 mi.
solidsuface is offline
post #2 of 12 (permalink) Old 08-01-2011, 06:48 PM
Well actually the final drive gears are always "meshed" together.
What you are describing is backlash, freeplay or slack.
The 2 1/2" movement is take up of backlash between gears in the whole drivetrain from the engine, transmission, front bevel gear assembly, driveshaft and final drive. I have never measured the freeplay or backlash in the drivetrain on my bike, but IMHO if you are not experiencing any serious "clunking" when you shift into gear, I wouldn`t worry about any perceived looseness.
BTW, welcome to the Vulcan madness.
Is the 750 your first motorcycle?
How long have you been riding? How many miles so far?
post #3 of 12 (permalink) Old 08-01-2011, 07:44 PM Thread Starter
Ring & Pinion
The clunking in the shifting is what lead me to measure the freeplay the way I did. I removed the fill cap on the final drive and rotated the rear tire, the pinion gear does not turn but the ring gear does turn one full tooth on the pinion.
I have 7300 miles on the bike now.
Actually I had (2) bikes in the 60's a Triumph cub and a Suzuki x six hustle.
Since the mid 90's I have been riding and restoring Cushman's
They say knowledge is power, I hope their right!
post #4 of 12 (permalink) Old 08-01-2011, 08:45 PM
It sounds almost, but not quite, like you are describing a broken tooth on a gear.
I`m stumped at the moment.
post #5 of 12 (permalink) Old 08-02-2011, 12:46 AM
If only it had 6th gear..
DavesVulster's Avatar
Seems like maybe the side tolerance between the pinion and ring mesh is too wide. Can you describe the clunking a little more? Like does it ever happen during acceleration? I'll try to check mine before I go to work in the morning and see how much play it has.
DavesVulster is offline
post #6 of 12 (permalink) Old 08-02-2011, 09:54 AM Thread Starter
Ring & Pinion
The tolerance between the ring and pinion is what I have been thinking, but since clymer's tells me you need special tools to work on the final drive!!!!!!!!!!
Clunking is only at shift, if I time things right, which is only about 50% of the I can avoid the clunk.
post #7 of 12 (permalink) Old 08-02-2011, 10:00 AM Thread Starter
Ring & Pinion
Thanks , but not a broken tooth.
post #8 of 12 (permalink) Old 08-02-2011, 10:03 AM Thread Starter
Ring & Pinion
post #9 of 12 (permalink) Old 08-02-2011, 10:21 AM
I think you are worrying about nothing. 2 inches a small amount of travel. Imagine a slice of pizza. As you get closer to the center the movement gets less and less.
At 7300 miles it is very unlikely to have any trouble in that area. However, you can check for metal grindings in the oil. Use a magnet tool retriver in the gear oil and check it for metal.
Hope this gives you peace of mind.
post #10 of 12 (permalink) Old 08-02-2011, 10:46 AM
JM2001's Avatar
Put the bike on the centerstand and in first gear. Rotate the tire until the gears mesh. Then rotate the tire in the opposite direction. Measure this freeplay amount. If within 2-3 inches I wouldn't worry about it.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
