cant get gear shift shaft out far enough to see circlip groove - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 6 (permalink) Old 05-26-2011, 03:57 PM Thread Starter
Hey guys, 1992 vulcan, got the engine pulled out for stator replacement. Gear shift shaft is loose. I can move it in and out of the engine about an inch or so, but I can not pull it out far enough to see the groove for the inner circlip. Both of the circlips are touching eachother at the outer circlip groove right now. I have both covers off and the linkage and pawl move and are in good shape. Any ideas on how to pull the shaft out far enough to get the inner circlip back in the groove without farther breaking down the engine?
Thanks for any info
firemedic is offline
post #2 of 6 (permalink) Old 05-26-2011, 05:16 PM
Welcome to the Vulcan madness firemedic.
I can`t help with the circlip, but will offer another suggestion.
Your bike is 20 years old and the crankshaft balancer dampers are likely beginning to deteriorate. The first sign is rubber chunks showing up in the screen behind the drain plug. Since your engine is already out, I would change them now. Just my 2 cents worth.
In one of Roach`s engine teardown videos he shows that his dampers were breaking down.
https://www.vn750.com/forum/showthread.php?t=18289
post #3 of 6 (permalink) Old 05-26-2011, 05:45 PM
just slide it down the shaft till it clicks, i couldn't really see mine either but it engaged.
Harley sportster fenders
custom raked front end
custom exhaust
vn800 tank and guages
modified seat and recovered
rear frame chopped
custom wiring harness
airbox removed
hzhardy is offline
post #4 of 6 (permalink) Old 05-27-2011, 07:54 PM Thread Starter
Dampers were done a couple years ago. Thanks for the advise though.
I tried to just slide it down, Would not click.. I plan on just making a spacer for the shaft.
post #5 of 6 (permalink) Old 05-28-2011, 04:44 PM
the rod may be bent inside the case were the little rod attaches.
custom exhaust
rear frame chopped
airbox removed
hzhardy is offline
post #6 of 6 (permalink) Old 06-01-2011, 01:30 AM
I've yet to see that rear groove; sucker hides itself pretty well. The first time I had the engine out, I couldn't get the inner clip to seat and said to hell with it. Second time, I decided to try again, and it slipped right in place. Go figger; guess you just gotta hold yer mouth right and wiggle and twist the shaft a little bit.
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
