Final Drive Oil Change - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 23 (permalink) Old 05-17-2011, 11:01 AM Thread Starter
I just changed the oil in my final drive and the old stuff came out very very dirty. I just bought the bike a couple weeks ago and the PO had the drive shaft replaced in '09. I am pretty sure that was the last time the oil was changed. So, I was wondering if this condition of the oil is normal?
2002 Vulcan 750
Iridium plugs
AGM Battery
More upgrades to come!
crispycarp is offline
post #2 of 23 (permalink) Old 05-17-2011, 01:58 PM
2 Vulcans
When I changed mine I didn't worry about the color of the old oil. I just collected it in a cup and after waiting a bit to allow settling, I put a magnet in the oil and drug it around the bottom the cup to see if it picked up any metal bits/shavings.
Didn't find anything so that made me happy and I refilled it with new oil and went on with my next project.
HIS - 2006 - Purchased with 1600 miles
Spline Lube, LED 3rd Brake Light in Sissy Bar, LED Brake Light Strobes, F&S Luggage Rack, F&S Engine Guard, F&S Extended Sissy Bar, Faria Voltmeter/VDO cup, 12v outlet, HF bulb
HERS - 2003 - Purchased with 4500 miles
Spline Lube,LED 3rd Brake Light in Sissy Bar, LED Brake Light Strobes, F&S Luggage Rack
F&S windshield, F&S Extended Sissy Bar, Faria Voltmeter/VDO Cup, HF bulb
mistereman1 is offline
post #3 of 23 (permalink) Old 05-17-2011, 05:25 PM
I guess it matters what oil you use. I highly reccomend Mobil One synthetic ...75w90. or any synth in the 70w~140 range.
The stuff does stink and it does get nasty looking fast. I try to change it every 10k.
post #4 of 23 (permalink) Old 05-17-2011, 08:14 PM
i like lucas gear oil.
I also like knifemakers photo.
Ghost-Rider is offline
post #5 of 23 (permalink) Old 05-17-2011, 08:24 PM
Originally Posted by Ghost-Rider View Post
...I also like knifemakers photo.
Who's head is that anyway?
dariv is offline
post #6 of 23 (permalink) Old 05-17-2011, 09:07 PM
She's my first.
post #7 of 23 (permalink) Old 05-17-2011, 10:11 PM
I highly recommend Mobil One synthetic ...75w90.
KM,
Any particular reason??
I need to change mine and was curious
VoIPDoc is offline
post #8 of 23 (permalink) Old 05-17-2011, 11:44 PM
gun slinger
centurynick's Avatar
I was going to run some marine pennzoil 80w90 lower unit gear oil. I mean if it can protect the gear cases,it should be able to stand up to my bike
......right???
2010' voyager
2005 1600 nomad sold
1987 kawasaki vulcan 750 SOLD
1985 kawasaki vulcan 700 parts bike maybe
lots of hand guns
3 cagers doors kicked in
centurynick is offline
post #9 of 23 (permalink) Old 05-18-2011, 09:12 AM
scuba's Avatar
here's a question, how do you know how much oil to add?
www.vulcanriders.us scuba
vn750.com scuba
vulcanforum.com scuba54220
vroc.org VROC # 32658 (scuba)
1984 kz750 ltd
1982 yamaha maxim 750
2002 nomad trike
1978 suzuki 250
1964 harley amf
1987 yamaha venture 1300
1984 honda silverwing
custom exhaust
custom mirrors
custom grips
custom floorboards
ride-on tire sealant
corbin seat and backrest
custom exhaust
willie & max saddle bags
scuba is offline
post #10 of 23 (permalink) Old 05-18-2011, 09:14 AM
Final drives are pretty harsh environments for an oil. They get hot, do alot of work, and the do not get circulated and filtered like engine oils. And we are talking about not alot of oil doing this work.
Synthetics shine in hard use applications, and can take high temps without suffering as much as organic oils. You don't need to change the FD oil as often, so a good synthetic just makes sense. I mentioned Mobil one only because it usually scores highest in independent tests.
Any "hypoid" gear oil in the 70-90 weight range will work, and any synthetic is likely better than any organic here.
I should point out that many times when you buy a "marine" or motorcycle oil... It is the same oil they sell for autos, they just have stuck on a new label and jacked up the price.
Unless your talking about a high performance boat, you can't really compare it to a high revving motorcycle engine.
