Clutch cable questions... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 4 (permalink) Old 05-06-2011, 03:18 PM Thread Starter
I was reading over the procedure for adjusting the clutch cable last night and it left me with a question that I couldn't find the answer to... According to the Clymers you should add slack to the clutch cable at the middle adjustment screw then turn the lever at the engine til just before the clutch releases... Are you supposed to turn the lever by hand?
2000 Vulcan 750
the_cruz is offline
post #2 of 4 (permalink) Old 05-06-2011, 04:32 PM
I haven`t had to adjust my clutch yet, but my understanding from reading the Clymer manual is, Yes turn the release lever at the engine by hand while setting that adjustment.
post #3 of 4 (permalink) Old 05-06-2011, 05:19 PM Thread Starter
Should it move easily or do you really put some muscle into it?
2000 Vulcan 750
the_cruz is offline
post #4 of 4 (permalink) Old 05-07-2011, 07:03 AM
'03 VN750 "Rosie"
bstew7890's Avatar
I did mine last. Year using the clymers procedure it will turn easily.
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
