Clutch release problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 2 (permalink) Old 04-29-2011, 07:57 PM Thread Starter
ifixf18s's Avatar
OK, lets see if i can explain this. I was having trouble installing my Bevel gear case. What i believe the problem is. is the pin (lets call it the gear pin) that ingages the clutch push rod was sticking to far out and was no longer engaging the release shaft gear. It got this way during the installation of the bevel gear case because the release lever got turned and i would spin it around to reposition it (im learning as i go). So what i think i can do to fix this without completly removing the clutch release is. I realigned the gear pin so it could engage the release shaft, spun the release lever so the gear pin would retract all the way. Then install the bevel gear case. Remove the clutch release lever and if needed Spin the release shaft so the gear pin touches the clutch push rod and reinstall the release lever lining up the gap and the rib. Does this make sense? I got so frustrated with this i just quit for the day had a beer watching hockey, and will try again tomarrow.
ifixf18s is offline
post #2 of 2 (permalink) Old 04-29-2011, 09:25 PM
Concert connoisseur
wib714's Avatar
its been to long since I did mine but when I took mine off there was a little gear inside that fell out. cant find the gear on the diagram but I believe the clutch cable hooks to it, I had to make sure it was installed all the way in the released position. dont know if this helps you at all cause its not very detailed hopefully some one else can explain it better than me
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
