'94 trouble shifting - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 15 (permalink) Old 04-27-2011, 03:06 PM Thread Starter
Mattman's Avatar
Hey gang,
I just got a '94 VN750 and have been riding it as much as I can the last week...something that didn't turn up during the test drive before I bought it is that, after a while, the bike is very difficult to downshift. The clicks feel very hard, and I swear that it feels like it is skipping gears on the way down. I'll decelerate from speed in 5th, click down once, twice, and then it feels like the bike will not shift any lower. So I come to a stop, and not only do I find that I'm sometimes in first (as verified by a missed shift up, into neutral, when I pull away) other times I actually am starting off in what feels like 2nd or 3rd.
The "positive neutral finder" so far hasn't been all that reliable for me because if I am not confident that I'm in first, clicking up while stopped will not always bring me to neutral.
I was told that the bike had an oil change right before I bought it but I'm thinking that I ought to do my own before I spend too much time wondering about this, but what else should I be considering? Is this a common symptom?
Any and all advice is welcome and appreciated! Thanks!
Matt
Matt
Passaic County, NJ
1994 VN 750
April 2011- 30K miles
TOC MCCT 4/2012
New-to-me extended backrest 5/2012
Tourmaster bags 5/2012
Replaced driveshaft coupler and final drive-- ignored the spline lube recommendation too long and got burned 8/2012
Back on the Road 9/2012
De-POOGSed 6/2013
NGK Iridium Plugs 7/2013
New AGM battery 4/2014
Mattman is offline
post #2 of 15 (permalink) Old 04-27-2011, 03:53 PM
Mcneuby's Avatar
Cool Trouble Shifting
I have a 94 that I bought last spring. Last fall I changed the oil using Castrol Syntec 10W-40. a full synthetic. I hadn't had what I would call a problem but it shifts noticeably better now. I'm not sure it will help but I think it would be worth a try.
Enjoy the Ride
Mcneuby
Mcneuby is offline
post #3 of 15 (permalink) Old 04-27-2011, 06:11 PM
Are you declutching in every gear on the way down?
Or shifting down more than one gear at a time?
I read something last week, that I do not quite understand, about why a motorcyle needs to declutch in every gear when downshifting.
Anybody else know if this is true? And why?
post #4 of 15 (permalink) Old 04-27-2011, 06:30 PM
clock152's Avatar
I had an old Honda that I had to do that with.
have you checked the side to side play in the shifter?
clock152 is offline
post #5 of 15 (permalink) Old 04-27-2011, 08:52 PM
dynajim's Avatar
Had the same issue. Had to adjust the clutch quite bit before it got better. Had to re-position the clutch arm too! I find that w/o double clutching on the way down I have those same issues though not as bad . But then I've always done that.Been riding for 45 yrs.
my .02
'94 VN 750 17k mi. Aqua, Memphis shade.
Acquired 2/2011
Oiled
Tank cleaned
New Fork seals
Idle jets-RT-3.0, Lft-2.5 turns
Sea Foamed
New Batt for grins
Stupid hose in the rt ear found and fixed
Major clutch adj.
New Petcock
New Shimko tires
De-goated before I got it.
Iridium plugs
YEA! New choke cable!!
Gonna do the Spline Lube soon(Chged tires before I found this site)
Replacement for my FXDWGI
Why didn't I find these before I spent $22 grand!!
dynajim is offline
post #6 of 15 (permalink) Old 04-28-2011, 04:41 PM Thread Starter
Mattman's Avatar
The play doesn't seem to be a problem...as the bike warms up (after 10-15 minutes) is when I begin to notice it. If anything, the shift linkage seems a little stiff
Matt
Passaic County, NJ
1994 VN 750
TOC MCCT 4/2012
De-POOGSed 6/2013
Mattman is offline
post #7 of 15 (permalink) Old 04-28-2011, 04:42 PM Thread Starter
Mattman's Avatar
As for double-clutching, hasn't seemed to be necessary, it doesn't seem to change anything really. Getting new oil and filter tonight and when it stops raining I'll be changing it out and see if that helps matters
Thanks
Matt
Matt
Passaic County, NJ
1994 VN 750
TOC MCCT 4/2012
De-POOGSed 6/2013
Mattman is offline
post #8 of 15 (permalink) Old 04-28-2011, 10:22 PM
dynajim's Avatar
HHmmnn. Well, there's enough guys on here with all kinds of experiance. Sombody will chime in with the info you need.
Acquired 2/2011
Oiled
Tank cleaned
New Fork seals
Sea Foamed
New Batt for grins
Major clutch adj.
New Petcock
New Shimko tires
Iridium plugs
dynajim is offline
post #9 of 15 (permalink) Old 04-29-2011, 12:07 AM
In case you didn't know, make sure you drain the oil from the side plug behind the kickstand and not the plug on the bottom. Pull the screen and make sure that's clean. I have someone at work that has a Vulcan and he has been doing the oil changes from the bottom, I had to tell him the proper way.
post #10 of 15 (permalink) Old 04-29-2011, 09:00 AM
deleted
1988 VN750[SIGPIC][/SIGPIC]
FlacoLove is offline
Tags
neutral.finder , shift , trouble
