No gears just neutral - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 19 (permalink) Old 04-24-2011, 09:22 PM Thread Starter
Well, after finally having a nice day with no chores to impede me taking a ride, it left me stranded. Pulled up to a stop sign and down shifted to what should have been 1st and I noticed it was in neutral. Won't go to any gear at all. Acts like a limp ****. No indication of it catching any gears anywhere. The neutral light remains on at all times. Bike runs great and sounds great but won't go anywhere now. I suppose I'll see what I can find and fix it and get rid of it after this. Too much bs with this bike and it's sad since when it running it's great and it looks awesome. But I refuse to be stranded and this is the first bike that has ever done that to me that couldn't be fixed on the spot and rode on home.
Sucks~
keltec is offline
post #2 of 19 (permalink) Old 04-24-2011, 10:38 PM
Sucks~
Sounds like the tie-rod between the shift lever shaft and the change lever shaft is broken. It is a known weak spot on earlier model bikes. It was superceded sometime in the mid `90s.
P/N 39110-1073
http://www.indyoem.com/fiche_section...1988&fveh=9031
What model year is your vn?
post #3 of 19 (permalink) Old 04-24-2011, 10:39 PM
Sounds like the spring for the pawl for the shifter strikes again. I was reading about this before, never had it happen to me. Someone will probably chime in on this for you. Good luck, should be a simple fix.
post #4 of 19 (permalink) Old 04-24-2011, 10:55 PM Thread Starter
Well, I'm a little more settled down now. I'll have to look into both possibilities concerning this issue. What is strange is that when I DO try to shift, it is very very loose but the shift lever does go back to position.
What the heck is the "pawl spring for the shifter"? Looked at the schematic for the shifter on Bike Bandit and didn't see anything called that. But will look again. Thanks
It does feel as though something has either broken or come completely loose.
I have the knawing feeling I'll be pulling the engine. If that is the case this bike will be down for quite some time as honey do's are stacked in front of bike repairs.
keltec is offline
post #5 of 19 (permalink) Old 04-24-2011, 11:14 PM Thread Starter
I guess my biggest concern is that I'll have to be tearing into the bike so deep. From what I can tell so far, I'll have to pull the engine out just to get to the shifting mechanisms. Unless, someone has some brilliant ideas (which wouldn't surprise me) of getting this done without the huge job.
keltec is offline
post #6 of 19 (permalink) Old 04-24-2011, 11:20 PM
Ok, I have not dismantled anything on the engine myself, BUT if shark is right, I believe this can be an easy fix.
1- Drop the oil
2- remove the left side external shift mechanism cover (with the oil level sight glass in it). Held by 6 cap screws I believe. Be careful with the gasket, but you will probably need a new one to reassemble.
The pawl is reference #13165 in the diagram in the link above.
the spring is ref.# 92081A
Not sure if the spring is likely to be broken or just fallen off.
I remember reading in an old post that someone built up worn tips on the pawl by welding with a MIG or TIG welder. So check the tips too.
The parts under this cover are the only tranny parts accesible without splitting the engine cases.
I hope it is this spring and not the tie-rod. Much easier repair.
post #7 of 19 (permalink) Old 04-24-2011, 11:31 PM
The fact that the shift lever return to it`s normal postion indicates to me that the tie-rod probably is not broken.
The spring ref# 92081B appears to be the one resisting the shift lever in the diagram.
shark88`s diagnosis is looking even better to me now.
post #8 of 19 (permalink) Old 04-25-2011, 12:08 AM
IMBoring25's Avatar
Mine with similar symptoms was as OlHossCanada describes. It was indeed the spring labeled 92081A, and it had just lost its springiness, for lack of a better explanation. While the cover can't come all the way off with everything else in place and some dexterity is needed to do the necessary manipulations with the cover hanging, it is not necessary to move the engine or the shaft.
IMBoring25 is offline
post #9 of 19 (permalink) Old 04-25-2011, 08:21 AM
Concert connoisseur
wib714's Avatar
time to play the "gas prices" card!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #10 of 19 (permalink) Old 04-25-2011, 09:10 AM
clock152's Avatar
one other thing to check... on the shifter.. make sure you only have about 1/4 inch play in it.. no more than that.. when I say play I mean slideing it in and out of the engine.. there are cerclips that can come off or slide.. you can use a small hose clamp to hold the shifter in place untill you have time to pull the engine.
clock152 is offline
