Throttle Cable Routing Path... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Transmission / Rear End
post #1 of 7 (permalink) Old 04-12-2011, 08:13 PM Thread Starter
artemis_f0wl's Avatar
Send a message via AIM to artemis_f0wl Send a message via Yahoo to artemis_f0wl Send a message via Skype™ to artemis_f0wl
Hello again!
I had to order replacement throttle cables recently after the old ones snapped. That being said, this is my first time ever replacing cables on a bike and I've learned the value of proper routing. The bad part is, I can NOT find any diagram or guidance on how to route these cables so they actually work! Can anyone point me toward some resource for how to get these routed properly? Any input would be appreciated!
NIL ILLEGITIMUS CARBORUNDUM
Phil aka Art
"Vanessa"
1995 VN 750 (bought as 2nd owner 11/2008)
26,440 miles
Stator replaced (55 Days!)
V&H Cruisers
Relocate rear turn signals
Highwayman Saddlemen bags
Wingerline Highway bars
Ear Shave
Rejet carbs
R/R relocate
Kuryakin ISO Duallys all around
HD Heritage seat
12" ape hangers
To Do:
Some sort of new grips
Mirrors
Paint Job- should I do it myself?
artemis_f0wl is offline
post #2 of 7 (permalink) Old 04-12-2011, 09:13 PM
cglennon's Avatar
It may not answer all your questions, but here is a similar thread.
Chris Glennon - Portland, OR
cglennon is offline
post #3 of 7 (permalink) Old 04-12-2011, 09:39 PM
KidChaos's Avatar
I just did this so I can describe it from memory if that helps.
From the handlebars it goes down behind the right side of the headlight. Through the metal wire holder attached to the right fork. Then behind the top of the right ear, exiting below the right ear, but behind (above) the bottom bolt on the ear. Runs along the bottom of the ear, mine runs above the spark plug but behind the spark plug wire and then attaches to the bracket and then the carbs.
Hope that helps
KidChaos is offline
post #4 of 7 (permalink) Old 04-13-2011, 08:31 AM
deleted
1988 VN750[SIGPIC][/SIGPIC]
FlacoLove is offline
post #5 of 7 (permalink) Old 04-13-2011, 08:51 AM
Into the Darkness
NetMatrix's Avatar
Make sure you spray a little WD-40 on both ends of BOTH cables to make sure they move and return freely with no snags. Plus it will extend the life of the cables as well.
English Version
ACCT to MCCT conversion video
https://www.vn750.com/forum/showthread.php?t=18235
ACCT to MCCT Conversion Thread created by wib714
https://www.vn750.com/forum/showthread.php?t=17917
Proximity Construction
NetMatrix is offline
post #6 of 7 (permalink) Old 04-13-2011, 09:44 AM
flitecontrol's Avatar
To avoid this problem, I taped the top of the new cable to the bottom of the old one and pulled. As the old one comes out, the new one is installed where it needs to go!
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #7 of 7 (permalink) Old 04-15-2011, 01:53 PM
spiral_72's Avatar
Hope that helps
I just did this last night, and I too 100% agree. The above description is perfect.
The fuel hose near the spark plug is a good idea. I noticed that last night, but didn't know what to do about it. THANKS!
spiral_72 is offline
